Prevent Yarbo Snow Blower Track Freezing – Winter Maintenance Tips
[2024] How to Avoid Freezing Tracks on Your Snow Blower
Winter weather can be harsh, especially for those responsible for keeping walkways and driveways clear of snow. One common issue faced by users of snow blower, Yarbo, is the freezing of tracks after extended periods of use. This article will guide you through the steps to prevent this problem, ensuring your yarbo stays operational and efficient throughout the winter season.
  1. Post-Snow Blow Maintenance
After each snow clearing session, it's crucial to perform a proper maintenance routine to prevent the tracks from freezing. The first step is to clean the area between the tracks and the walking motor. This can be done by:
  • Turning off the bot and allowing it to cool down to avoid any burns or injuries.
  • Using a brush or a similar tool to remove any accumulated snow, ice, or debris from the tracks and the walking motor.
  • Inspecting the tracks for any signs of wear or damage that could lead to further complications.
By keeping the tracks and walking motor clear of snow and ice, you reduce the likelihood of the tracks freezing to the track, which can cause operational issues.
  1. Lubrication After Every Four Charges
Regular lubrication is essential to keep the tracks moving smoothly and to prevent them from freezing. After every four charges, it's recommended to apply lubricating grease to the tracks. For detailed instructions on how to apply lubricating grease, refer to the following resources:
Lubrication not only reduces friction but also creates a barrier that can help prevent ice from forming between the tracks and the walking motor.
  1. Thawing Frozen Tracks
If, despite your best efforts, the tracks freeze, there are steps you can take to thaw them out:
  • Move the Yarbo to a slightly warmer indoor area, such as a garage or a shed, to allow the ice to melt naturally.
  • Avoid using any heat sources that could cause the plastic tracks to warp or the motor to overheat.
  • Once the tracks are thawed, clean and lubricate them again to prevent future freezing.
By following these simple maintenance tips, you can significantly reduce the risk of your snow blower's tracks freezing during winter operations. Regular cleaning, lubrication, and proper storage can extend the life of your yarbo and ensure it's ready to tackle the next snowfall. Stay proactive with your yarbo's care, and you'll keep your paths clear and safe all winter long.
    • [2024] How to Replace Your Track to Fit the Snow
      Welcome to the Yarbo Track Replacement Guide. This guide provides a step-by-step process for safely removing and replacing the tracks on your Yarbo Core. By following these instructions, you can ensure a smooth and safe replacement process without ...
    • [2024] Perform Routine Maintenance
    • [2024] How to Replace Track Side Plate
      Purpose of the Track Side Plate The Track Side Plate is an important component designed to prevent snow from accumulating inside the tracks and reaching the motors, which could lead to operational malfunctions during snow removal. Your Yarbo Core ...
    • [2024] Yarbo Snow Blower User Manual
      Note: This page is part of our legacy support content. Yarbo’s Knowledge Base has now moved to the new Yarbo Wiki. To access the latest user manual for the Snow Blower and stay up to date with all features and guides, please visit the Yarbo Wiki: ? ...
    • [2024] Yarbo Lawn Mower Maintenance Guide
