Optimal Snow Blower Settings for Yarbo – Overlap, Auger Speed, Height & Deflector Guide
[2024] Snow Blower Settings Recommendations
   Overlap (inches) Settings
   1. For thicker snow or if there are missed spots, choose 11.88 inches.
   2. To improve clearing efficiency, choose 0 inches (though this may result in some missed snow).
   3. A balanced option would be 5.88 inches (recommended).
   Auger Speed Mode
   1. Recommended settings: Quiet or Mild. Both light and heavy snow can be cleared with no speed restrictions.
   2. Robust and Turbo modes are generally used for clearing wet snow, but they have speed limitations, only usable on Slow or Medium speed.
   Auger Minimum Height (inches)
   1. For flat surfaces (e.g., concrete, asphalt), set the height to 0 inches.
   2. For brick surfaces, cracks, or uneven roads, set the height between 0.4 to 0.6 inches.
   3. For gravel or muddy surfaces, set the height between 0.8 to 1.2 inches.
   4. For non-snow activities, set the height to High.
   Deflector Angle
   1. To avoid throwing snow onto neighbors' property, choose an angle between -5 to 5 for both the lowest and highest positions.
   2. If you find the snow throw distance to be too short, choose an angle between 40 to 50 for both positions.
   3. To automatically adjust the snow throw distance based on the machine's position, select an angle between -5 to 50 for both the lowest and highest positions. (The farther the machine is from the snow throw area, the farther the snow will be thrown, and vice versa).
    • [2024] Yarbo Snow Blower Quick Start Guide
      Please download the attached file for the Quick Start Guide of the 2024 Snow Blower Mower.
    • [2024] How to use plow mode?
      How to use plow mode on Yarbo app After the plow blade has been installed, find the Plow Mode button in Yarbo Settings, click the Plow Mode button to enter the Plow Mode settings, and turn on Plow Blade Mode in the Plow Mode settings. plow mode icon ...
    • [2024] How to Operate the Auger Safely?
      The Yarbo Snow Blower is designed to efficiently clear snow from surfaces, but handling the auger safely is essential to prevent injury or equipment damage. This guide provides important safety considerations to ensure the safe operation of the Yarbo ...
    • [2024] Settings to Improve Mowing Efficiency with Yarbo Lawn Mower
      The Yarbo lawn mower offers flexible settings that allow you to find the ideal balance between enhancing mowing efficiency and achieving a better cutting result. Whether you’re looking to speed up the mowing process or ensure a cleaner cut, there are ...
    • [2024] How does Yarbo deal with wet snow?
      The plow blade is designed for handling wet snow, which tends to be heavier and more challenging to clear. Wet snow typically forms when the temperature rises to around -5°C, causing some snow to melt and become sticky. Using the Plow Blade: After ...
