[2024] What if Yarbo loses, or has a weak GPS signal?
GPS signal issue is usually conplicated, but we have a few tips you can check first to help you.
Check the Data Center environment
The Data Center is supposed to have a clear view of the sky. Ensure the Data Center has a stable GPS connections - at least 25 satelites.
Check Yarbo Core environment
The Yarbo Core is supposed to have a stable GPS connection - around 20 satelites. In a work area, users should set No-Go-Zones for sky obstacles like trees or concrete sheds to prevent the Yarbo from losing GPS signals.
Ensure hardware connection
- Unplug and plug your internet cable connected to the Data Center or your WiFi router.
- Check your Yarbo antenna connections. Tightening the RTK wire connections can be helpful.
Reboot Yarbo and Data Center
Power cycling the Yarbo Core and Data Center, restarting the entire system.
Reboot Yarbo Core:
You can do this simply by the phone app -> Yarbo Setting -> Safety Setting -> Restart Yarbo System.
Reboot Data Center:
The easiest way is unpluging the POE cable and pluging it again.
- Related Articles
- [2024] Setting up a Data Center through your App- This guide provides step-by-step instructions for setting up your Data Center, along with key considerations to ensure Yarbo maintains a strong, stable signal connection. You’ll also learn how to seamlessly reinstall your Data Center to a new ...
- [2024] What should I do if my Data Center flashes green light all the time?- What is the Data Center? The Data Center serves as the base station responsible for transmitting RTK signals to your Yarbo, ensuring precise positioning for optimal performance. Optimal Installation Guidelines for the Data Center Set The key ...
- [2024] What if Yarbo Exits the Mapped Area- Under normal circumstances, Yarbo operates effectively within the mapped area. However, there may be instances where Yarbo exits this area due to inaccuracies in positioning. Here is the most common issue related to boundary breaches and basic ...
- [2024] Why is the Data Center Flashing Red?- 1. Check for damage to the RTK Antenna on the Data Center If the RTK antenna is damaged, it can cause the Data Center to flash a red light 2. Verify if the Data center has been upgraded to the latest version If you have upgraded the Data Center, it ...
- [2024] How to keep your Yarbo up-to-date(App & Data Center Firmware)- Staying up-to-date is crucial for any technology, including your Yarbo. This ensures optimal performance, enhanced features, and the fixing of any bugs that may have been discovered. In this tutorial, we will guide you through the process of updating ...
