What is No-Vision Zone?
[2024] What is No-Vision Zone?
What Is a No-Vision Zone?
As the name suggests, a No-Vision Zone is an area where the camera-based obstacle detection is disabled. This means that within this zone, your Yarbo lawn mower will not use its cameras to detect or bypass obstacles.
When Should You Use It?
If you notice that your Yarbo lawn mower is avoiding areas that are actually safe to mow, you can mark those areas as No-Vision Zones to allow the mower to operate normally.
Yarbo uses advanced image segmentation technology to detect and avoid obstacles. However, in some cases, the camera might misidentify safe areas—such as shadows or certain textures—as obstacles, causing the mower to avoid them unnecessarily. In such cases, a No-Vision Zone can be a helpful solution.
 Important: Please ensure that all areas marked as No-Vision Zones are safe, as camera-based obstacle avoidance will be disabled within these zones.
How to Create a No-Vision Zone
  1. Go to the Edit Map page.
  2. Tap Create, then select No-Vision Zone.
    Create No-vision ZoneCreate No-vision Zone
  3. You have two options:
  • Manually drive your Yarbo to outline the zone.
  • Use a preset template for quicker setup.
    • [2024] Yarbo User Manual
    • [2024] Yarbo Lawn Mower User Manual (Italian)
      Note: This page is part of our legacy support content. Yarbo’s Knowledge Base has now moved to the new Yarbo Wiki. To access the latest user manual for the Lawn Mower and stay up to date with all features and guides, please visit the Yarbo Wiki: ? ...
