Why Is Your Data Center Flashing Red? – Yarbo Troubleshooting
[2024] Why is the Data Center Flashing Red?
1. Check for damage to the RTK Antenna on the Data Center
      If the RTK antenna is damaged, it can cause the Data Center to flash a red light
2. Verify if the Data center has been upgraded to the latest version
      If you have upgraded the Data Center, it is necessary to reinstall the Data Center.
      If you haven't upgraded it yet, Please first update the Data Center to the latest version,
      and then reinstall the Data Center.
The red flashing light on the Data Center is a new light signal introduced after our firmware update.
It indicates that there is a significant deviation in the latitude and longitude during detection.
This issue usually occurs when the machine has just been received, or when the Data Center has been moved a long distance and powered on again.
This is a self-correction mechanism. If you encounter this situation, ensure that the Data Center is upgraded to the latest version and then reinstall the Data Center.
    • [2024] What should I do if my Data Center flashes green light all the time?
    • [2024] How to keep your Yarbo up-to-date(App & Data Center Firmware)
      Staying up-to-date is crucial for any technology, including your Yarbo. This ensures optimal performance, enhanced features, and the fixing of any bugs that may have been discovered. In this tutorial, we will guide you through the process of updating ...
    • [2024] Yarbo User Manual
    • [2024] Setting up a Data Center through your App
