How to Fix Map Drift in the Yarbo App – GPS Positioning Guide
[2024] Yarbo Position Misaligned with the Map
Under normal circumstances, the map within the app should accurately reflect Yarbo's relative position in the real environment. However, there may be instances where GPS signal instability causes a discrepancy between Yarbo's displayed position on the app and its actual location in the real world.
Example of issues:
There's a map drift issue with the bot in the app; however, the bot is accurately stopped at the docking station.
map drift
Here are some suggestions to address this issue:
  1. Check GPS Signal Strength: Ensure that Yarbo is operating in an area with strong GPS signal coverage. Weak signals can lead to inaccuracies in positioning.
  2. Correct Map Drift: Click on the "Correct Map Drift" button to automatically correct map drift.
How to Correct Map Drift:
  1. Make Sure Your Yarbo is Parked Accurately on the Docking Station If map drift occurs, you will need to manually maneuver your Yarbo. you will need to park your Yarbo exactly on the Docking Station.
  1. Operating on the Yarbo APP You can go to the “My Yard” map, find the settings option and select the “Correct Map Drift” option. Click on it and wait for a while, your Yarbo will correct the map automatically!
map drit correction
By taking these steps, you can work towards ensuring that the app's map more accurately represents Yarbo's true position.
If the problem continues, contact Yarbo's customer support. They can offer further assistance and may be able to provide a solution or identify if there's a hardware issue.
    • [2024] Maintaining Data Center and Docking Station Position for Accuracy
      For Yarbo to function at its best, it's crucial to ensure that both the Data Center and the Docking Station are placed and maintained in the optimal positions. Correct placement of these components helps Yarbo accurately navigate, recharge ...
    • [2024] Troubleshooting Guide: Yarbo Recharge Failure
      When you encounter a failure in recharging your Yarbo upon its return to the charging station, consider the following parallel factors that could contribute to the issue: Location and Positioning: Ensure that your Yarbo is within the map range. Your ...
    • [2024] Setting up Docking Station through your App
      This guide provides step-by-step instructions for setting up your Docking station, along with key considerations to ensure Yarbo maintains a wonderful charging base for wireless charging. You’ll also learn how to seamlessly reinstall your Docking ...
    • [2024] What if the Yarbo Fails to Charge Right on the Docking Station?
      If you encounter a situation where the Yarbo fails to charge on the docking station, this passage will guide you through troubleshooting steps and potential solutions. Step 1: Check Battery Level Ensure that the battery level is below 85%. The ...
    • [2024] Yarbo User Manual
