The auger of your Yarbo might be rusted over time due to constant contact with snow during operation.
You can easily manage these minor rusty areas with a paint pen. Here's a step-by-step guide to help you through the process:
Preparation
Prepare the tools: a paint pen, some cotton buds, 75% ALC, a clean cloth.
Protect yourself: please remember to wear protective gloves and other necessary protective gear to avoid getting hurt by the sharp parts of the machine.
Prepare your Yarbo:
Use your controller to lift the module part to its highest.
Press the Stop Button and the Power Switch to turn off your Yarbo.
Remove the battery pack.
Unscrew the 24 bolts to detach the protective fence.
Applying the Paint Pen
Dip the cotton bud into 75% alcohol and use it to clean off the rust in the affected areas.
Use clean cloth to wipe off the alcohol.
Shake the paint pen to ensure the paint is well-blended, and apply it evenly on the rusty areas.
Once you're done, please remember to reinstall the protective fence with your protective gloves.
We advise regular checks for rust on your Yarbo to ensure early maintenance and prevent any impact on its performance.
Grease helps maintain smooth rotation of the drive and road wheels, improving performance and extending service life. Upon several operations, grease may degrade, so regular refills are necessary. Scenarios There are a couple of scenarios in which we ...
As winter approaches its end in many areas, it's time to prepare your snow blower for off-season storage. Spending time on prepping the machine for long-term storage will not only help maintain its performance but also improve its longevity. 1, ...
Yarbo, a technologically advanced robot, is designed with numerous complex components that work in tandem to deliver high-performance operations. To ensure the sustained performance and longevity of Yarbo, we strongly recommend regular inspections, ...
To protect your Yarbo, we offer a machine body cover and a module cover when your Yarbo won't be in use for extended periods. These covers are designed to safeguard your machine from dust and debris. How to Apply REMOVE the Battery Pack and make sure ...
