Environmental Requirements for RTK Base
The RTK base is minimally affected by temperature fluctuations. However, it is crucial to avoid exposing it to water as it is not waterproof. It can only be used in the temperature range spans from -30°C to 60°C (-22°F to 140°F). Therefore, whether placed indoors or outdoors, please ensure that the RTK Base is used within the specified temperature range and is not exposed to water.
- Make sure to place the RTK Base Indoors as it is not waterproof.
- The tolerant temperature range spans from -30°C to 60°C (-22°F to 140°F).
- Avoid placing the RTK Base near any metal materials.
[2023] A Comprehensive Overview about the RTK Base
What is the RTK Base? RTK, or Real-Time Kinematicis a method that boosts the precision of GNSS (Global Navigation Satellite System) signals like GPS, Glonass, Galileo, and BeiDou. The main purpose of the base station is to remain fixed in one ...
【Troubleshooting】What Should I Do if my RTK Base Flashes Green Light All the Time?
How to reset base?
Sometimes, you may need to reset the Yarbo base. This guide will walk you through the steps to safely reset the base and set up your Yarbo device again. Access Yarbo Settings and Select “Reset Base” Open the Yarbo app. Go to the “Yarbo Settings” ...
[2023] Wi-Fi Network Connection Guide for Yarbo Base
Step 1: Connect to Yarbo Base Hotspot 1. Open your mobile device and ensure that the Wi-Fi feature is enabled. 2. Access the Wi-Fi settings on your mobile device. 3. In the Wi-Fi network list, locate and select the Yarbo Base you want to operate. The ...
[2023] Clarification for the RTK and the Lora Cable
We've noticed that there have been some questions about the RTK/Lora cable, and we'd like to provide some clarification on this subject. To begin with, there are two cables attached to the RTK base - one for the RTK Antenna, and another for the Lora ...
