Essential Tips for Setting Up Your Unit in Snowy Conditions
Modes of Network Configuration
Hotspot Mode Tips: For optimal mapping performance, we recommend utilizing Hotspot Mode to ensure a prompt response without any delays. When operating in Hotspot Mode, please ensure you stay within a 10ft range of Yarbo. Upon completing the mapping ...
Grease Lubrication Purchase Guideline
Thank you for choosing Yarbo. To ensure the longevity and optimal performance of your Yarbo device, please follow the grease lubrication guidelines below to help you choose and apply the right grease. Grease Lubrication Types: All of these three ...
Charging Instructions for Yarbo Device
Charging Yarbo with the Wired Charger Before charging Yarbo, check the voltage switch on the wired charger and set it to your home's AC voltage. Connect the wired charger to an electrical outlet and the charging port under the rear cover of Yarbo. ...
Yarbo Snow Blower S1 Limitations Instruction
Thank you for choosing our Snow Blower S1 device! While our product offers advanced features and capabilities, it is important to be aware of its limitations to ensure safety and efficiency of use. This instruction manual outlines the functionalities ...
A Comprehensive Overview about the RTK Base
What is the RTK Base? RTK, or Real-Time Kinematicis a method that boosts the precision of GNSS (Global Navigation Satellite System) signals like GPS, Glonass, Galileo, and BeiDou. The main purpose of the base station is to remain fixed in one ...
