[2023] Grease Lubrication Purchase Guideline
Notes
Thank you for choosing Yarbo. To ensure the longevity and optimal performance of your Yarbo device, please follow the grease lubrication guidelines below to help you choose and apply the right grease.
Grease Lubrication Types: All of these three types are applicable
  • High Vacuum Grease
    • Recommended for applications with high vacuum conditions.
    • Ideal for sealing and lubricating vacuum systems.
  • Vacuum Grease
    • Suitable for general-purpose lubrication in vacuum environments.
    • Provides effective sealing and protection against moisture and contaminants.
  • Silicone Lubricating Material
    • Versatile lubricant suitable for various applications.
    • Offers excellent thermal stability and water resistance.
Grease Characteristics: The grease should satisfy the following criteria
  • Morphology: Opt for a grease with a paste-like consistency for ease of application and adherence to surfaces.
  • Viscosity:  Choose a grease with high viscosity to ensure adequate lubrication, especially in challenging operating conditions.
  • Volatility: Opt for a grease with low volatility to minimize evaporation and ensure long-lasting lubrication.
Temperature Range:
  • Grease should be suitable for temperatures ranging from -30°C to 100°C (-22°F to 212°F).
  • Ensure the selected grease maintains its consistency and effectiveness across the specified temperature range.
Compatibility:
  • Ensure the chosen grease is non-corrosive to Yarbo device components, including rubber and nylon parts.
Additional Tips:
  1. Frequency of Application:
  • Regularly reapply grease based on usage and environmental conditions to ensure consistent protection.
  • Create a lubrication schedule to maintain optimal performance.
  1. Cleaning:
  • Before reapplication, thoroughly clean the contact points to remove old grease, dirt, and debris.
  • Use appropriate cleaning agents to ensure a clean and smooth surface.
  1. Storage:
  • Store the grease in a cool, dry place away from direct sunlight to prevent degradation.
  • Ensure the container is tightly sealed to prevent contamination.
  1. Consult Yarbo Support:
  • If unsure about the right grease or application technique, contact Yarbo's technical support for guidance.
    • 2023 Yarbo Lawn Mower User Manual
      Please download the attached file for the User Manual of the 2023 Lawn Mower.
    • How often do I need to replace the cutting blades?
      Maintaining the cutting blades of your lawn mower is essential for achieving a well-manicured lawn. Whether you're dealing with regular lawn care or tackling thicker grass, keeping your blades sharp and in good condition is key. Here's a ...
    • What should I do if Yarbo lawn mower vibrates abnormally during mowing?
      Stop Operation Immediately: Cease mowing and allow all moving parts to come to a complete stop before proceeding. The instructions about how to control Yarbo physically are shown in the artical "Physical Controller Instruction". Use the Emergency ...
    • Hot Swap Warning
      To ensure operational safety and equipment integrity, special attention must be paid to hot swap operations when using Yarbo devices. Below are the detailed hot swap warnings and related instructions: What is Hot Swapping? Hot swapping refers to the ...
    • Inspect Yarbo Regularly
      Yarbo, a technologically advanced robot, is designed with numerous complex components that work in tandem to deliver high-performance operations. To ensure the sustained performance and longevity of Yarbo, we strongly recommend regular inspections, ...
