How to maintain the mower's wheels?
Regular Wheel Cleaning
Clean the underside wheels regularly to prevent mud and weeds from entangling, which can affect the wheel's movement and performance. Please refer to “How to clean the Yarbo lawn mower?”.
Routine Inspections
Check for any cracks and whether the wheel axles are loose, damaged, or deformed. If there is any damage or if the wheel's steering becomes unresponsive, contact Yarbo for professional maintenance and repairs.
What should I do if Yarbo lawn mower vibrates abnormally during mowing?
Stop Operation Immediately: Cease mowing and allow all moving parts to come to a complete stop before proceeding. The instructions about how to control Yarbo physically are shown in the artical "Physical Controller Instruction". Use the Emergency ...
How to clean and maintain the mower's rain sensor for accurate detection?
The rain sensor is located at the top front of the mower module, covered by a small silicone with grooves. You can use a soft brush to clean the grooves to ensure no dust or other obstruction filled between two small yellow conductive probes. During ...
How to perform routine maintenance of the mower's blades?
Clean the underside cutting blades regularly, refer to "How to clean the Yarbo lawn mower?". Avoid cutting blades from coming into contact with hard surfaces such as stones and bricks. Avoid prolonged exposure to humid environments, maintain ...
Cleaning Lawn Mower Module Detach the lawn mower from the universal body. Raise the lawn mower from the side and place the lawn mower on Module Vertical Stand, please refer to the following picture. Utilize a high-pressure water gun or water hose to ...
What is the difference between U-turn and Three-point turn?
U-turn vs. Three-point turn: a brief description U-turn: Imagine you are operating a lawnmower on a spacious lawn. When you get to the edge and need to turn around, making a U-turn will be a great help. You simply need to operate the lawnmower, let ...
