How to properly reinstall the blades after cleaning or maintenance?
Properly reinstalling the blades on your lawn mower after cleaning or maintenance is crucial for safe and efficient operation. Follow these steps and refer to the provided video link for detailed guidance.
Safety Reminders
- Always use the specified blades for your lawn mower.
- Handle blades carefully to avoid injury.
- Regularly inspect and maintain your lawn mower to ensure safe and efficient operation.
Steps:
Power Down and Remove the Mower Module
- Turn Off Yarbo: Remove the rear cover. Press the power button to turn off Yarbo.
- Remove Anti-Theft Bolts: Remove the anti-theft bolts from the battery cover on both sides.
- Remove the Battery Cover and Disconnect the Battery: Grasp both sides of the battery cover and lift it off. Disconnect the battery from the universal body and carefully take it out to ensure safety and prevent accidental activation during maintenance.
- Detach the Mower Module from the Universal Body: With the battery disconnected, detach the mower module for easier access to the blades.
Secure the Mower on the Vertical Stand for Module
Raise the lawn mower from the side and place it on the Vertical Stand for Module. This stand provides stability and allows you to safely access the underside of the mower. Refer to the image for proper positioning.
Remove the Cutting Blades
Before handling the blades, wear gloves to protect your hands from sharp edges. Use the Phillips-head screwdriver provided in the lawn mower Box to unscrew the Cutting Blades Bolts.
Install the New Blades
- Position the New Blades: Align the hole of the blade and the hole of The Cutting disc.
- Secure the Blades: Reinsert the bolts and tighten them with the Phillips-head screwdriver. Make sure the blades are firmly secured to prevent movement during operation.
Final Check and Reassembly
After installing the new blades, double-check that all bolts are tightly secured. Lower the mower from the Vertical Stand for Module and reattach it to the universal body. Reconnect the battery and replace the battery cover, securing it with the anti-theft bolts. Ensure everything is correctly assembled before powering Yarbo.
For a more detailed visual guide, please watch the
video tutorial. The video provides step-by-step instructions to help you understand and execute these steps effectively.
If you have any further questions or need assistance, please contact our support center.
Properly reinstalling the blades on your lawn mower after cleaning or maintenance is crucial for safe and efficient operation. Follow these steps and refer to the provided video link for detailed guidance. Safety Reminders Always use the specified ...
How to clean the Yarbo lawn mower?
Cleaning Lawn Mower Module Detach the lawn mower from the universal body. Raise the lawn mower from the side and place the lawn mower on Module Vertical Stand, please refer to the following picture. Utilize a high-pressure water gun or water hose to ...
How often do I need to replace the cutting blades?
Maintaining the cutting blades of your lawn mower is essential for achieving a well-manicured lawn. Whether you're dealing with regular lawn care or tackling thicker grass, keeping your blades sharp and in good condition is key. Here's a ...
How to perform routine maintenance of the mower's blades?
Clean the underside cutting blades regularly, refer to "How to clean the Yarbo lawn mower?". Avoid cutting blades from coming into contact with hard surfaces such as stones and bricks. Avoid prolonged exposure to humid environments, maintain ...
