In the event that the auger ceases to rotate, or encounters difficulties when cleaning snow, it may become necessary to consider the replacement of the shear pins. Here are the instructions of replacing shear pins:
Please ensure wearing protective gloves before any operation.
Please inspect the specified locations on the auger shaft for any broken shear pins.
If a shear pin is found to be missing, it is important to replace the broken shear pins to protect the auger.
To replace it, take a shear pin and cotter pin inside the Shear Pins and Cotter Pins Pack.
Select a shear pin and align it with the corresponding hole.
Insert the shear pin securely.
Affix the cotter pin on top of the shear pin.
For visual instructions, please refer to the video below:
Please refer to the troubleshooting guide below when encountering any issues Please refer to the guidance The Yarbo Tool for fixing the internet connection
Please refer to this article for assistance in case your Rover Hotspot not being detected on your mobile device, there are steps you can take to troubleshoot and resolve the issue. This guide will walk you through the process, and you can use the ...
If you observe your Yarbo light consistently cycling through red-green-blue-white flashes, it may indicate an underlying issue. This troubleshooting guide is designed to assist you in identifying the potential causes behind the blinking and offers ...
