How to set the route pattern of my Yarbo?
What is the route pattern setting for?
The route pattern setting in Yarbo is the predetermined path or pattern Yarbo follows while operating. The setting allows Yarbo to cover the entire lawn efficiently and uniformly, ensuring that no areas are missed and that the lawn is mowed in a systematic and desirable manner.
There are 4 typical patterns you can consider with Yarbo's customized features.
  • Parallel
  • Spiral
  • Checkboard
  • Diamond
How to modify the setting of route pattern?
  1. Starting from Modify Map page, you will see your plans for different areas, where you can modify settings for different areas by clicking the icon shown below.
  2. Scrolling down the page of Area Settings. The route pattern feature is shown with four selectable options. You can choose one that is most desirable in your current mowing plan.
  3. Click √ in the top right corner to save the setting.
    • What are the advanced settings I can consider and how to modify these settings?
      Advanced settings are customized work settings for each working area, which enable a more detailed working pattern within Yarbo's automated processes. You can adjust overlap paths, rotation degree, and other settings according to the specific needs, ...
    • What is the 'route mode' and how to adjust it?
      The 'Route' refers to the automated working path generated by Yarbo within your workspace. When implementing a plan, Yarbo will follow the route precisely for snow-blowing operations. We offer two route modes, Parallel and Circular, designed to ...
    • Instruction of Parameters Setting for Work Area
    • Instructions for setting snow-throwing directions
      1. While conducting the cleaning process, Yarbo is designed to expel snow, requiring the configuration of snow-throwing directions within its cleaning area. 2. Once the snow-throwing directions are set, Yarbo will automatically direct the snow in the ...
