The 'Route' refers to the automated working path generated by Yarbo within your workspace. When implementing a plan, Yarbo will follow the route precisely for snow-blowing operations. We offer two route modes, Parallel and Circular, designed to ...
The plow blade mode can only be enabled or disabled when the snow blower module S1 is installed. The auger in the work plan will automatically disable once the snow plow blade mode is enabled. By default, the plow blade mode is disabled. It is not ...
