【Must Read】How to use the Plow Blade safely?
For your safety and to safeguard your property during product usage, please adhere to the following guidelines:
  • Installation and Inspection:
    • Before attaching the plow blade accessory to the auger housing, ensure that the Yarbo is powered off and completely stopped.
    • Inspect the plow blade for any damages or defects. Not recommend to use it if any issues are detected.
  • Proper Attachment:
    • Follow the quick start guide precisely when attaching the plow blade accessory to the front of the auger housing.
    • Ensure that the plow blade is securely fastened to the auger housing to prevent detachment during operation.
    • The edges of the snow plow blade may be sharp, especially the edge of the wear bar. Use care when handling the blade.
  • Operating Procedures:
    • Engage the plow blade accessory only when necessary and disengage it when not in use to prevent unnecessary wear and tear.
    • Do not make any adjustments or repairs on the plow blade while the auger is operating.
    • Do not operate the Yarbo with the plow blade at high speeds, especially when approaching obstacles or turning corners. High-speed impacts can cause loss of control and result in accidents or injuries.
  • Clear Work Area:
    • Before starting the Yarbo with the plow blade accessory, ensure that the work area is clear of any obstacles or debris that could interfere with the operation.
  • User Caution:
    • Do not allow bystanders or unauthorized personnel in the vicinity of Yarbo while it is in operation.
    • Check if the plow blade is securely fastened to the auger housing.
    • Do not disassemble and assemble the plow blade repeatedly, which may lead to screw damage.
  • Emergency Procedures:
    • In case of any malfunction or unexpected behavior while using the plow blade accessory, immediately power off the Yarbo and address the issue before resuming operation.
    • How to Use Snow Plow Blade Mode?
      The plow blade mode can only be enabled or disabled when the snow blower module S1 is installed. The auger in the work plan will automatically disable once the snow plow blade mode is enabled. By default, the plow blade mode is disabled. It is not ...
    • 【Must Read】Safety Guidelines about Yarbo
      Product Usage For the safety of yourself and your property during product usage, please adhere to the following guidelines: WARNING: Keep Away from Children: Never allow children to operate the product. Adult Supervision: Only let adults operate the ...
    • Scenarios and Capabilities of Plow Blade
      The plow blade is not advised for use in the following situations: It is not recommended for use when snowfall rates exceed 2 inches per hour, particularly with wet or densely packed snow. On driveways that exceed 30 feet in width, we are designing a ...
    • How to choose and adjust obstacle avoidance mode for my Yarbo?
      What is the obstacle avoidance mode for? Avoidance mode is designed to automatically adjust Yarbo to your lawn situation. Each obstacle avoidance mode automatically has a default of camera sensitivity and ultrasonic sensors, in order to ensure smooth ...
    • Safety tips for charging and maintaining the mower's battery
      The battery is a crucial component of the Yarbo, and its condition directly affects the operational efficiency and safety of the device. By following proper charging and maintenance practices, you can effectively extend the battery's lifespan, ensure ...
