How to view the mower's historical mowing records?
Yarbo Lawn Mower currently supports viewing mowing records generated during the execution of its work plan. To view these records, please follow these steps in the Yarbo App:
  1. Open the Yarbo App: Locate and tap on Settings" to access the feature.
  2. Access Work Plan History: Once in the "Settings" page, tap the "Work Plan History" in the bottom to view the history.
  3. Review Mowing Records: In the "Work Plan History" section, you can see detailed operation records, including time of operation, completion status, cleaned area, duration of the mowing session, etc.
    • How to create a work plan for lawn mowing?
      Create a work plan Click the Map button on the top right corner of Yarbo's home page. Click the work plan button. Click the Plus icon located in the corner. Choose the work area and pathway that needs to be included in the plan. Name the plan and ...
    • Where to find the 'Work Plan' feature within the APP?
      1. You can click on the button at the bottom of Yarbo's homepage to quickly view and start your Work Plan. 2. To access your Work Plan, click on the "Map“ icon in the top right corner of Yarbo's homepage, then click the "Work Plan" button to view, ...
    • How to locate the 'Work Plan' feature inside the application?
    • How to use the 'Work Plan' feature?
      1. Create a Plan You can select areas on the map that you want to clean and combine them to create a plan. You can customize multiple plans to effectively meet your snow-clearing requirements. You could click on the "Map" icon located in the top ...
    • 2023 Yarbo Lawn Mower Quick Start Guide
      Please download the Quick Start Guide for the Yarbo Lawn Mower.
