Instruction for Sidewalk Feature
What is Sidewalk?
The Sidewalk feature is a sophisticated element designed to establish connections between diverse areas without encountering constraints. It also functioning as a versatile pathway, adeptly facilitate seamless connectivity, offering an efficient means of navigation between distinct zones.
Where to Find Sidewalk?
- Begin by clicking on the "Map" icon located in the top right corner of Yarbo's homepage.
- Look for the "Modify Map" button within the map interface.
- Click on "Modify" to access the Sidewalk option.
![](https://support.yarbo.com/galleryDocuments/edbsn60d4dde514f5c07e0b669dcc69304f53c8c9fabf561fc70634df800cfdefd30071c31fe781946cd92e5b5fe59f7f760f?inline=true)
How to Use Sidewalk?
![](https://static.zohocdn.com/zoho-desk-editor/static/images/file.png)
- The route of the sidewalk is determined by how you guide Yarbo to draw a sidewalk on your map, which is a personalized route not generated by a closed shape.
- The sidewalk must be connected to an area or pathway.
- A sidewalk on the map can be a continuous line that allows for turns. If you wish to use the sidewalk feature to clean an area without creating a work area, you can either create multiple sidewalk lines within that area or establish a continuous sidewalk with turnarounds, resembling a U shape.
- A sidewalk is a single linear path, distinct from a closed area, and it can be seamlessly connected to specific areas.
- The sidewalk cannot be cross the no-go zone.
- The parameters of each sidewalk can be customized.
- Initiate Sidewalk Addition: Locate and click the "Add Sidewalk" button on the toolbar.
- Start Drawing: Click on the "Start" button to define your sidewalk on the map area, please ensure that the sidewalk is connected to an area or pathway.
- Select Throw Direction: Slide the boundary to indicate the direction of snow throwing for the sidewalk.
- Complete Drawing: After selecting the throw direction, click on the "Next" button to finalize and conclude the drawing process.
- Confirmation: Confirm the drawn sidewalk and its designated direction. If satisfied, proceed with any additional steps or save the changes.
What is Sidewalk? The Sidewalk feature is a sophisticated element designed to establish connections between diverse areas without encountering constraints. It also functioning as a versatile pathway, adeptly facilitate seamless connectivity, offering ...
How to set parameter for sidewalk?
How to locate the sidewalk setting page? Access 'My Map' Page: Begin by clicking on the icon located in the upper-right corner, directing you to the 'My Map' page where you manage and customize your map settings. Enter Modification Mode: Click on ...
How to Use Schedule Feature?
What is a Schedule? The schedule feature within the app allows Yarbo to establish specific time periods for automated cleaning of work areas. By creating a schedule, Yarbo seamlessly operates without the need for manual intervention, ensuring that ...
