[2023] LED Indicator Instruction
To know more about the detailed insights into the LEDs indicators of Yarbo device, physical controller, docking station functionality, and RTK Base, please refer to this article for help.
    • Yarbo Snow Blower S1 Limitations Instruction
      Thank you for choosing our Snow Blower S1 device! While our product offers advanced features and capabilities, it is important to be aware of its limitations to ensure safety and efficiency of use. This instruction manual outlines the functionalities ...
    • What are the steps to resolve typical problems encountered with the Yarbo Tool?
      The Yarbo Tool should be used in the following situations Connectivity Issues with both Yarbo device and RTK Base : The Yarbo app can not connect to the rover via the hotspot connection. 【Rover -> Network-> Wi-Fi Connection】 The hotspot of Yarbo's ...
    • How to Fix the Common Issues with Yarbo Tool?
    • Instruction for Sidewalk Feature
      What is Sidewalk? The Sidewalk feature is a sophisticated element designed to establish connections between diverse areas without encountering constraints. It also functioning as a versatile pathway, adeptly facilitate seamless connectivity, offering ...
    • Instruction of 'Yarbo Sharing'
      For collaborative work on your Yarbo, the following steps will guide you in granting other members access: Launch the Yarbo application on your device and navigate to your personal account page. Locate and select the option labeled "Yarbo Sharing". ...
