The snow ice cover is specifically designed to safeguard the space between the module and universal body, preventing any accumulation of ice or snow in this area that could potentially affect performance.
How to Use the Snow Ice Cover
REMOVE the battery pack and ensure that the Yarbo is STOPPED.
Put the cord in the slit on the top of the snow ice cover, and button it upbehind the cord.
Secure the cover by tying the four belts to the lifting handles of the snow blower module and the lifting handles of the universal body.
Important note: DO NOT tie the belts to the RTK antenna as this could lead to damage.
To protect your Yarbo, we offer a machine body cover and a module cover when your Yarbo won't be in use for extended periods. These covers are designed to safeguard your machine from dust and debris. How to Apply REMOVE the Battery Pack and make sure ...
While the Yarbo S1 is adept at handling wet snow, its snow-clearing capability can sometimes be impacted due to the particular conditions of the snow. In such instances, we suggest the following strategies to optimize your Yarbo S1's performance: ...
Carefully secure the protective cover over the connection cable. This will help prevent any potential damage from snow or rain to the cable, the inner components and prevent un-authorized removal of the front module.
Store your Snow Blower in the garage or a sheltered area to keep your Yarbo safe. Remove the rear cover, press the power button to turn off Yarbo(IMPORTANT!). Remove this cover from Snow Blower module, with Allen Key #1. Screw the connector onto the ...
In the mapping process, snow-throwing directions should be set for your pathway and work areas (including sidewalks), which guides the chute to blow snow in the direction(s) of your choice. While the setting of these directions largely depends on the ...
