Keep Battery Pack Healthy
DO NOT leave the battery pack inactive for more than 3 months.
Leaving the battery pack inactive for an extended period will significantly reduce its performance and cause fast degradation.
DO charge the battery pack for 15 minutes at least once per 3 months.
Lithium-ion battery packs slightly self-discharge over time. Charging the battery pack for 15 minutes at least once per 3 months will be enough to keep the battery active.
DO consider replace the battery pack at a noticeable decrease of its performance. The battery pack's lifespan is influenced by operation frequency and total working hours. If the operating time per full charge noticeably decreases, please consider replacing the battery pack.
Keep Firmware Up-To-Date
New firmwares will always provide better product capabilities. The new versions will be released regularly on our App, and your firmware will be updated automatically through Yarbo App's build-in Over-The-Air (OTA) technology when Yarbo and your ...
Keep Yarbo at its Best Performance
Before and after every operation, DO: Check the status of the discharge chute Notice: Operating with a clogged discharged chute can significantly shorten the motor's lifespan and lead to subpar snow removal performance. Caution: SHUT DOWN Yarbo ...
【Before Any Maintenance】Protect yourself and Deactivate Yarbo
Before any maintenance, please: DO NOT wear open-toed shoes or be barefoot. Wear suitable Personal Protective Equipments (PPE), including protective gloves and protective goggles. Tie up your hair and tuck in your shirt. DISCONNECT and REMOVE Battery ...
Inspect Yarbo Regularly
Yarbo, a technologically advanced robot, is designed with numerous complex components that work in tandem to deliver high-performance operations. To ensure the sustained performance and longevity of Yarbo, we strongly recommend regular inspections, ...
How to Store Yarbo After Winter?
As winter approaches its end in many areas, it's time to prepare your snow blower for off-season storage. Spending time on prepping the machine for long-term storage will not only help maintain its performance but also improve its longevity. 1, ...
