Maintaining RTK and Docking Station Position for Accuracy
![](https://static.zohocdn.com/zoho-desk-editor/static/images/file.png)
DO NOT change the location of the RTK or the Docking Station. Any change in location requires a full data reset, reinstalling the docking station and re-mapping from scratch to guarantee precise positioning.
Securing the RTK Antenna
Make sure the RTK Antenna structure is securely fastened. Any movement in the structure of the antenna will directly affect the accuracy of Yarbo’s positioning.
Environmental Requirements for RTK Base
The RTK base is minimally affected by temperature fluctuations. However, it is crucial to avoid exposing it to water as it is not waterproof. It can only be used in the temperature range spans from -30°C to 60°C (-22°F to 140°F). Therefore, whether ...
Securely Fasten the Antennas
1. Make sure to securely fasten the antennas on both the Yarbo Main Body and the external RTK pole. 2. Make sure to tighten the antennas just enough, but be careful not to overdo it as it could cause damage.
