Scenarios and Capabilities of Plow Blade
The plow blade is not advised for use in the following situations:
- It is not recommended for use when snowfall rates exceed 2 inches per hour, particularly with wet or densely packed snow.
- On driveways that exceed 30 feet in width, we are designing a specific "plow mode" which will allow Yarbo to move the snow to the sides of your driveway.
- Over terrain that is uneven or sloped or if your driveway has significant damage (such as broken concrete).
- On surfaces comprised of gravel or mud (unless your gravel driveway already has a frozen layer for Yarbo to work on that is smooth).
The plow blade is advised for use in these situations:
- When the snowfall rate per hour is 2 inches or less, regardless of whether it's dry, wet, or packed snow.
- On driveways with a width of about 30 feet, ensuring that the accumulated snow is manageable to push.
- It is recommended to use the plow blade on smooth, flat terrain, while caution is advised to avoid uneven or sloped areas, as well as driveways with significant damage such as broken concrete.
- The plow blade proves to be highly effective on paved surfaces, offering efficient traction and operation.
FAQ for HaLow
Background We've noticed that there are issues with the rover's strategy during AP switches, particularly in areas with poor Wi-Fi coverage, which can lead to connection issues. We're working on updating our Wi-Fi switching strategy to ensure that, ...
A Comprehensive Overview about the RTK Base
What is the RTK Base? RTK, or Real-Time Kinematicis a method that boosts the precision of GNSS (Global Navigation Satellite System) signals like GPS, Glonass, Galileo, and BeiDou. The main purpose of the base station is to remain fixed in one ...
Is there a reason to use Wi-Fi instead of 4G ?
Please refer to the information below if you are curious about why we are recommending you use Wi-Fi to instead of 4G. What is the Wi-Fi Network mode? Wi-Fi mode refers to the connection method through WiFi, which enables Yarbo to connect directly to ...
Yarbo Snow Blower S1 Limitations Instruction
Thank you for choosing our Snow Blower S1 device! While our product offers advanced features and capabilities, it is important to be aware of its limitations to ensure safety and efficiency of use. This instruction manual outlines the functionalities ...
