Please refer to the troubleshooting guide below when encountering any issues Please refer to the guidance The Yarbo Tool for fixing the internet connection
Please refer to this article for assistance in case your Rover Hotspot not being detected on your mobile device, there are steps you can take to troubleshoot and resolve the issue. This guide will walk you through the process, and you can use the ...
If you observe your Yarbo light consistently cycling through red-green-blue-white flashes, it may indicate an underlying issue. This troubleshooting guide is designed to assist you in identifying the potential causes behind the blinking and offers ...
Press and hold "SELECT + B" to turn off, or it will automatically shut down if no operations are conducted within 5 minutes. Please be mindful when moving the controller between outdoor and indoor environments. The changes in temperature can cause ...
