[2024] What if the Docking Station Cannot be Placed in Steep Areas?
To maximize Yarbo’s performance and prevent potential damage, it's essential to place the docking station on a stable, level surface—especially in areas with uneven terrain. If positioned on a slope, Yarbo may slide, leading to charging interruptions, reduced efficiency, and potential damage to the device.
To address this, we recommend
creating a level platform for the docking station by leveling a section of the terrain and reinforcing it with a sturdy, weather-resistant board. Start by selecting a location with minimal slope, if possible, and use a shovel or leveling tool to excavate and flatten the area. Lay down the board to create a solid foundation that Yarbo can dock onto reliably. Ensuring the platform’s tilt is less than one degree is crucial, as even slight angles may impact docking alignment and charging stability.
A leveling tool or smartphone app can help confirm the platform’s angle before placing the docking station. Regularly check the level of the platform to account for any shifting caused by weather or natural ground settling. Taking these steps will ensure Yarbo docks and charges effectively, providing a safe and dependable docking area and minimizing risks for long-term use.
[2024] Maintaining Data Center and Docking Station Position for Accuracy
For Yarbo to function at its best, it's crucial to ensure that both the Data Center and the Docking Station are placed and maintained in the optimal positions. Correct placement of these components helps Yarbo accurately navigate, recharge ...
[2024] What is "Pathway,Working Area and Sidewalk"
In the Yarbo app, there are three key types of working areas that help Yarbo operate efficiently: Pathway, Working Area, and Sidewalk. Each area serves a specific purpose to guide Yarbo's tasks effectively. Here’s an overview of each type: Pathway ...
[2024] Setting up Docking Station through your App
This guide provides step-by-step instructions for setting up your Docking station, along with key considerations to ensure Yarbo maintains a wonderful charging base for wireless charging. You’ll also learn how to seamlessly reinstall your Docking ...
[2024] How to Add and Manage a Docking Station in the Yarbo App
Additional Notes: You can add multiple Docking Stations and Start Points within the Yarbo App. However, during an active Work Plan, only one Docking Station or Start Point can be selected at a time. Each Docking Station must be assigned to a specific ...
<br> Additional Notes: You can add multiple Docking Stations and Start Points within the Yarbo App. However, during an active Work Plan, only one Docking Station or Start Point can be selected at a time. Each Docking Station ...
