[2023] Clarification for the RTK and the Lora Cable
We've noticed that there have been some questions about the RTK/Lora cable, and we'd like to provide some clarification on this subject.
To begin with, there are two cables attached to the RTK base - one for the RTK Antenna, and another for the Lora Antenna. The cables provided with your Yarbo are 33ft long. Additionally, as a Kickstarter backer, you'll receive two 33ft extension cords and connectors as a Kickstarter Stretch Goal gift. This allows you to extend the length to a maximum of 66ft, if necessary.
๐Ÿ’กShould you wish to replace our cables with your own, please ensure they meet the following specifications:
๐…๐จ๐ซ ๐ญ๐ก๐ž ๐‹๐จ๐ซ๐š ๐œ๐š๐›๐ฅ๐ž, ๐ข๐ญ ๐ฌ๐ก๐จ๐ฎ๐ฅ๐ ๐›๐ž: ๐’๐Œ๐€(๐Ÿ๐ž๐ฆ๐š๐ฅ๐ž) ๐ญ๐จ ๐’๐Œ๐€(๐ฆ๐š๐ฅ๐ž), ๐ฐ๐ข๐ญ๐ก ๐š๐ง ๐ข๐ฆ๐ฉ๐ž๐๐š๐ง๐œ๐ž ๐จ๐Ÿ ๐Ÿ“๐ŸŽ ๐จ๐ก๐ฆ๐ฌ.
๐…๐จ๐ซ ๐ญ๐ก๐ž ๐‘๐“๐Š ๐œ๐š๐›๐ฅ๐ž, ๐ข๐ญ ๐ฌ๐ก๐จ๐ฎ๐ฅ๐ ๐›๐ž: ๐’๐Œ๐€(๐Ÿ๐ž๐ฆ๐š๐ฅ๐ž) ๐ญ๐จ ๐’๐Œ๐(๐ฆ๐š๐ฅ๐ž), ๐ฐ๐ข๐ญ๐ก ๐š๐ง ๐ข๐ฆ๐ฉ๐ž๐๐š๐ง๐œ๐ž ๐จ๐Ÿ ๐Ÿ“๐ŸŽ ๐จ๐ก๐ฆ๐ฌ.
Moreover, it's vital to ensure that the ๐ญ๐ก๐ซ๐ž๐š๐ ๐ฅ๐ž๐ง๐ ๐ญ๐ก ๐Ÿ๐จ๐ซ ๐ญ๐ก๐ž ๐’๐Œ๐€(๐Ÿ๐ž๐ฆ๐š๐ฅ๐ž) ๐ข๐ฌ ๐Ÿ๐Ÿ๐ฆ๐ฆ.
    • [2023] A Comprehensive Overview about the RTK Base
      What is the RTK Base? RTK, or Real-Time Kinematicis a method that boosts the precision of GNSS (Global Navigation Satellite System) signals like GPS, Glonass, Galileo, and BeiDou. The main purpose of the base station is to remain fixed in one ...
    • Does the RTK Antenna Or LoRa Antenna Require a "Line of sight" to Yarbo?
      No, they don't. Understanding the logic behind the RTK System and the rover enables you to answer this question. Yarbo doesn't rely on direct visibility of the RTK System(RTK Antenna, LoRa Antenna and RTK Base). However, installing the RTK Antennas ...
    • Securing the RTK Antenna
      Make sure the RTK Antenna structure is securely fastened. Any movement in the structure of the antenna will directly affect the accuracy of Yarboโ€™s positioning.
    • Environmental Requirements for RTK Base
      The RTK base is minimally affected by temperature fluctuations. However, it is crucial to avoid exposing it to water as it is not waterproof. It can only be used in the temperature range spans from -30ยฐC to 60ยฐC (-22ยฐF to 140ยฐF). Therefore, whether ...
    • Securing Cable Cover for Weather Protection
      Carefully secure the protective cover over the connection cable. This will help prevent any potential damage from snow or rain to the cable, the inner components and prevent un-authorized removal of the front module.
