What is 'Work Plan'?
Work Plan refers to the snow cleaning plan you want your Yarbo to execute. Differenciating plans would enable you to clean just a single working area as a plan or to clean multiple working areas at once as how you combined your plan with different areas.
The working mode is like the pictures below, each work plan enables to work with just a single working area and also would work perfectly with several areas as a combination plan depends on your selection setting.
Work plan enables you to make cross combinations based on your different cleaning frequency requirements to targeted areas. With this function, Yarbo's flexibility would be tremendously promoted.
    • The introduction of 'Work Plan'
      Work Plan refers to the snow cleaning plan you want your Yarbo to execute. Differenciating plans would enable you to clean just a single working area as a plan or to clean multiple working areas at once as how you combined your plan with different ...
    • How to use the 'Work Plan' feature?
      1. Create a Plan You can select areas on the map that you want to clean and combine them to create a plan. You can customize multiple plans to effectively meet your snow-clearing requirements. You could click on the "Map" icon located in the top ...
    • How to create a work plan for lawn mowing?
      Create a work plan Click the Map button on the top right corner of Yarbo's home page. Click the work plan button. Click the Plus icon located in the corner. Choose the work area and pathway that needs to be included in the plan. Name the plan and ...
    • How to locate the 'Work Plan' feature inside the application?
      1. You can click on the button at the bottom of Yarbo's homepage to quickly view and start your Work Plan. 2. To access your Work Plan, click on the "Map“ icon in the top right corner of Yarbo's homepage, then click the "Work Plan" button to view, ...
    • Where to find the 'Work Plan' feature within the APP?
