What if I want to relocate the RTK antenna?
If the RTK antenna is moved to a different position, the current auto-plan map would need to be deleted and recreated. The entire map is constructed based on the precise location of the RTK. The logistical positioning of the map would be shifted following the relocation of the RTK.
If you have any further questions or need assistance, please feel free to send an email to
support@yarbo.com.
What if I want to relocate the Docking Station or RTK antenna?
Once your docking station and RTK antenna are set up, we advise not moving them. But if you need to relocate them, make sure to follow the instructions for "Reinstall the docking station" and "Reinstall the RTK" in the app. This is important because ...
Securing the RTK Antenna
Make sure the RTK Antenna structure is securely fastened. Any movement in the structure of the antenna will directly affect the accuracy of Yarbo’s positioning.
Does the RTK Antenna Or LoRa Antenna Require a "Line of sight" to Yarbo?
No, they don't. Understanding the logic behind the RTK System and the rover enables you to answer this question. Yarbo doesn't rely on direct visibility of the RTK System(RTK Antenna, LoRa Antenna and RTK Base). However, installing the RTK Antennas ...
【Troubleshooting】What Should I Do if my RTK Base Flashes Green Light All the Time?
Why mower always lose the GPS?
The reason and its solutions: 1.Satellite signals for both RTK and Rover antennas are block by obstructions such as buildings or trees Remove the obstruction or relocate the RTK antenna to an area with a strong GPS signal. Reset the RTK base station ...
