Common Causes of GPS Signal Loss in Yarbo & How to Troubleshoot
[2024] What Would Cause Yarbo to Lose GPS Signals?
Maintaining a stable GPS signal is essential for Yarbo to function efficiently. While Yarbo’s advanced system ensures smooth operation, several factors can affect its GPS performance. This guide covers common causes of GPS signal loss and how to troubleshoot them effectively.
GPS Icon Colors and Their Meanings
  • Green Icon: GPS is online and connected – Yarbo is functioning properly.
  • Yellow Icon: Medium GPS signal – Yarbo is still operational, but performance may be affected.
  • Red/Gray Icon: No GPS signal – Yarbo cannot receive a GPS signal and will not operate correctly.
Common Causes and Troubleshooting Solutions
1. No Halow or 4G Connection for Data Center and Yarbo Rover
Cause: The Data Center and Yarbo rover need Halow or 4G connectivity for reliable GPS operation.
Solution:
  • Check the network settings for both the Data Center and Yarbo rover.
  • If the problem persists, contact Yarbo Support for further assistance.
2. Satellite Signals Blocked by Obstructions
Cause: Objects like buildings, trees, or other obstacles can block satellite signals from reaching the Data Center and Yarbo rover antennas.
Solution:
  • Move the Data Center or reposition the rover to an area with a clearer view of the sky.
  • Swap the antennas on the left and right sides of the Yarbo rover to optimize signal reception.
  • If the issue continues, contact Yarbo Support.
3. Loose Connections at the Data Center
Cause: The connections between cables and the Data Center may not be secure.
Solution:
  • Check all cables and ensure the connections to the Data Center are tight and secure.
  • If the issue remains unresolved, contact Yarbo Support for further guidance.
4. Technical Issue with the Data Center
Cause: An internal issue or error may occur in the Data Center.
Solution:
  • Check the indicator lights on the Data Center for any error messages.
  • If the indicator is in red, try to replug POE port and contact Yarbo Support immediately for assistance.
5. Components Malfunction in the Yarbo Device
Cause: Internal components of Yarbo may not be functioning properly, disrupting GPS signals.
Solution:
  • Inspect all connections and cables between Yarbo and the Data Center to ensure they are undamaged and properly connected.
  • Verify that all antennas are properly installed and tightened.
  • Reset Yarbo and reconfigure default settings if necessary.
  • If the issue persists, contact Yarbo Support for further help.
6. Incorrect Adjust Angle on the Diagnosis Page
Cause: The diagnosis page displays an incorrect angle value (e.g., -1 or something other than 1), indicating a calibration issue.
Solution:
  • Check if Yarbo is positioned under any obstruction.
  • Ensure the HaLow connection is stable and functioning properly.
  • Confirm that the Data Center (DC) connection is normal.
  • Contact Yarbo Support if the problem remains unresolved.
    • [2024] What Factors Affect GPS Signal Quality?
      For Yarbo, you can see several RTK statuses in the App diagnosis page: rtk_status = 4: Fixed Solution — [High accuracy (cm level)] The status Yarbo needs to run autonoumously. At this point, the machine’s RTK module has obtained accurate RTK ...
    • [2024] What if Yarbo loses, or has a weak GPS signal?
      GPS signal issue is usually conplicated, but we have a few tips you can check first to help you. Check the Data Center environment The Data Center is supposed to have a clear view of the sky. Ensure the Data Center has a stable GPS connections - at ...
    • [2024] What if Yarbo Exits the Mapped Area
      Under normal circumstances, Yarbo operates effectively within the mapped area. However, there may be instances where Yarbo exits this area due to inaccuracies in positioning. Here is the most common issue related to boundary breaches and basic ...
    • [2024] Yarbo User Manual
    • [2024] Troubleshooting Guide: Yarbo Recharge Failure
      When you encounter a failure in recharging your Yarbo upon its return to the charging station, consider the following parallel factors that could contribute to the issue: Location and Positioning: Ensure that your Yarbo is within the map range. Your ...
