[2024] When Do You Need to Draw a No-Go Zone?
The No-Go Zone refers to enclosed areas within Yarbo’s working area where you do not want it to enter. While Yarbo’s stereo depth perception allows it to recognize and avoid many obstacles automatically, certain areas still require manual no-go zones to ensure optimal performance and safe operation.
Key Areas to Draw No-Go Zones
Swimming Pools and Water Features
- Yarbo cannot operate in or near water, and entering these areas could result in damage.
- Recommendation: Set a no-go zone around pools, fountains, and ponds to prevent accidents.
Flowerbeds and Gardens
- While Yarbo can navigate under trees and detect common obstacles, delicate plants or garden beds may need extra protection.
- Recommendation: Draw no-go zones around flowerbeds, vegetable patches, and newly planted areas.
Restricted Areas
- Prevent Yarbo from entering spaces you want to keep off-limits, such as pet zones, tool storage areas, or seasonal setups.
- Recommendation: Use no-go zones to block off restricted spaces, especially if the objects are temporary.
Large Fixed Obstacles
- Yarbo can avoid trees and shrubs automatically, but large or complex obstacles, such as parked vehicles, furniture, or heavy equipment, may require manual restriction.
- Recommendation: Set no-go zones around parked cars, playground equipment, or seasonal decorations to avoid interference.
Areas Where No-Go Zones Are Not Necessary
Trees and Bushes
- Yarbo automatically detects these obstacles and marks them on the map.
Navigating under trees
- With visual fusion navigation and odometry (ODOM), Yarbo stays on track without manual no-go zones.
[2024]What is "Mapping"
Mapping Work Area Click the Create A Map button at the bottom of the interface. First, turn Yarbo back to the docking station and click the start button. Click to draw work area's boundaries. Then please manually drive Yarbo to the perimeter of the ...
[2024] How to use no-go zone template?
Create No-Go Zone Template Open the Yarbo App and tap Enter My Yard on the home screen. Tap the Edit Map icon in the top‑right corner to switch into map‑editing mode. Edit Map Tap the Create button at the bottom of the screen. Create From the list, ...
[2024] Setting up a Data Center through your App
[2024] What is No-Vision Zone?
What Is a No-Vision Zone? As the name suggests, a No-Vision Zone is an area where the camera-based obstacle detection is disabled. This means that within this zone, your Yarbo lawn mower will not use its cameras to detect or bypass obstacles. When ...
[2024] Instruction of Setting Page of Yarbo APP
The Yarbo Settings Page provides you with complete control over all the essential aspects of your Yarbo device, allowing you to make adjustments, update settings, and access valuable information. This guide will take you through each feature of the ...
