Why mower always lose the GPS?
The reason and its solutions:
1.Satellite signals for both RTK and Rover antennas are block by obstructions such as buildings or trees
2.Technical issue with RTK base
- Check the light indicator of the basestation for any error message. If the indicator light is red, please network for base. If the indicator light is flashing red, try different RTK antenna locations, ensure 120° view of sky.
- lf the indicator is rapidly flashing red, the RTK antenna may be damaged and please contact us for further assistance.
3.No internet connection or unstable internet connection for RTK base or Yarbo rover
- Configure the network connection for both the RTK base and Yarbo rover.
- If the issue persists, contact us for further assistance.
4.Components Malfunction with Yarbo
- Restart your Yarbo.
- Check all connections and cables of RTK base to ensure they are securely plugged in and not damaged.
- Reset Yarbo and reconfigure all the default settings.
- Related Articles
- What should I do if Yarbo Lawn Mower stops working suddenly?- Error message on the app Machine overcurrent:Yarbo is stuck by hard surfaces such as stones and bricks, please check and remove them. If the issue persists, contact us for further assistance. Battery overheating:Please place the battery or Yarbo in a ...
- What do I do if Yarbo leaves patches of uncut grass?- These patches of uncut grass is not in the working area Please redraw the map and add these areas to the working area to make sure your Yarbo cuts the grass in the next automatic planning. These patches of uncut grass is draw as no-go zone Please ...
- 2023 Yarbo Lawn Mower User Manual- Please download the attached file for the User Manual of the 2023 Lawn Mower.
- 2023 Yarbo Lawn Mower Quick Start Guide- Please download the Quick Start Guide for the Yarbo Lawn Mower.
- How to clean the Yarbo lawn mower?- Cleaning Lawn Mower Module Detach the lawn mower from the universal body. Raise the lawn mower from the side and place the lawn mower on Module Vertical Stand, please refer to the following picture. Utilize a high-pressure water gun or water hose to ...
