Step 1: Connect to Yarbo Device Hotspot
1. Open your mobile device and ensure that the Wi-Fi feature is enabled.
2. Access the Wi-Fi settings on your mobile device.
3. In the Wi-Fi network list, locate and select the Yarbo device you want to operate, typically identified by the SN number ending in Yarbo. The default hotspot name should be something like "Yarbo_rover_XXXX".
4. For the initial connection, enter the default password (87654321).
5. Wait for your mobile device to successfully connect to the Yarbo device hotspot.
1. Open the Yarbo APP, choose the desired Yarbo device, click on the settings option, and then click on "Wi-Fi" to enter the device Wi-Fi configuration page.
2. In the Yarbo APP, select the Wi-Fi network you wish to connect to and enter the password.
3. Ensure the entered Wi-Fi password is accurate, then click the confirm button.
4. The Yarbo device will attempt to connect to the specified Wi-Fi network; please wait for the device to connect successfully.
Step 3: Reconnect Mobile Device to Regular Wi-Fi Network
1. Return to the Wi-Fi settings page on your mobile device.
2. From the Wi-Fi network list, choose the regular Wi-Fi network to which you want to reconnect.
3. Enter the password for the Wi-Fi network.
4. Wait for your mobile device to successfully reconnect to the regular Wi-Fi network.
Step 4: Operate the Device via Yarbo APP
1. In the Yarbo APP, verify that the Yarbo device has successfully connected to the Wi-Fi network.
2. Explore the APP features and select the desired operation.
