[2024] How does Yarbo deal with wet snow?
The plow blade is designed for handling wet snow, which tends to be heavier and more challenging to clear. Wet snow typically forms when the temperature rises to around -5°C, causing some snow to melt and become sticky.
Using the Plow Blade:
After attaching the plow blade, Yarbo can effectively "push" snow out of your working area. For optimal snow removal, set the auger height as low as possible.
Using the Snow Blower in Wet Snow:
While snow chunks may stick to the snow blower at times, it can still clear your yard effectively. For the best performance, set the movement speed to "medium" (in the app under Settings -> Work Preference).
[2024] How to use plow mode?
How to use plow mode on Yarbo app After the plow blade has been installed, find the Plow Mode button in Yarbo Settings, click the Plow Mode button to enter the Plow Mode settings, and turn on Plow Blade Mode in the Plow Mode settings. plow mode icon ...
[2024] Yarbo User Manual
[2024] How to Remove the Snow Blower Protection Fence
The protection fence on your Yarbo snow blower module plays an important role in keeping components safe during transport and basic operations. However, there may be instances where you need to remove it, such as for maintenance or to install the ...
