Troubleshooting Yarbo Recharge Failure: Causes & Solutions
[2024] Troubleshooting Guide: Yarbo Recharge Failure
When you encounter a failure in recharging your Yarbo upon its return to the charging station, consider the following parallel factors that could contribute to the issue:
  1. Location and Positioning:
    1. Ensure that your Yarbo is within the map range. Your Yarbo can only recharge effectively within this specified area you have drawn before.
    2. Confirm that your Yarbo is not positioned directly above the wireless charging pad. When your Yarbo is parked precisely over the pad, it cannot initiate the recharging process. Instead, manual control is required to start the charging sequence.
  2. RTK Signal Quality:
    1. Assess the quality of the RTK signal. A strong and stable signal is crucial for proper operation. If the signal is weak or unstable, consult the relevant diagnostic article for guidance on improving the RTK signal quality.
  3. Positioning Accuracy:
    1. Investigate if your Yarbo stopped incorrectly on the charging station during the recharge attempt. In such cases, flipping over the charging station and check if the cables are connected properly. Capturing detailed photographs can help in diagnosing the issue. Contacting customer service with these visuals will provide them with valuable information to assist further.
  4. Manual Intervention:
    1. As a last resort, manually relocate your Yarbo onto the charging station. Should your Yarbo still fail to recharge, refer to the provided solutions for potential causes and remedies: [2024] What if the Yarbo Fails to Charge Right on the Docking Station?
In case none of these measures resolves the problem, reaching out to customer service remains advisable for professional assistance tailored to your specific situation.
    • [2024] Yarbo User Manual
    • [2024] What if the Yarbo Fails to Charge Right on the Docking Station?
      If you encounter a situation where the Yarbo fails to charge on the docking station, this passage will guide you through troubleshooting steps and potential solutions. Step 1: Check Battery Level Ensure that the battery level is below 85%. The ...
    • [2024] How to recharge Yarbo
      Four ways to recharge Yarbo 1. Using the Physical Controller: Drive Yarbo back to the docking station with the physical controller. After approximately 3 minutes, Yarbo will announce "ready to charge" and "start charging," and will then begin ...
    • [2024] What is "Docking Station"
      The Docking Station is a smart charging platform specifically designed for Yarbo. It provides seamless wireless charging and auto-return functionality, ensuring the device stays powered and operational without manual intervention. Key Features: ...
    • [2024] Maintaining Data Center and Docking Station Position for Accuracy
      For Yarbo to function at its best, it's crucial to ensure that both the Data Center and the Docking Station are placed and maintained in the optimal positions. Correct placement of these components helps Yarbo accurately navigate, recharge ...
