Maximize Patrol Mode with Yarbo SAM Module – Setup & Scheduling Guide
[2024] How to Make the Most of Patrol Mode with the Yarbo SAM Module?
Attach the SAM module to your Yarbo core, and your yard robot can help monitor your yard 24/7 in patrol mode, detecting any unexpected visitors and ensuring you're immediately notified of every event.
How to Draw a Patrol Line in Patrol Mode:
  1. Click “Enter My Yard” to access the map interface, then click “Edit Map” in the top-right corner.
  1. Click “Create” and choose “Patrol Line.”
Patrol Line SettingPatrol Line Setting Page
  1. Move your Yarbo to the desired starting point of the patrol line. Once there, tap “Start” to begin drawing your patrol line.
Patrol Line Drawing PagePatrol Line Drawing Page
Note: The starting point of your patrol line should be within the green frame shown in the screenshot (the docking station), the pathways, or within your work area. It cannot be set in an unknown area.
  1. Once you've finished drawing the patrol line, tap "Next" to complete the process.
If you’re not satisfied with the route, you can always redraw the patrol line.
Note: Similar to the "Sidewalk" feature in the Yarbo Snow Blower, the patrol line in patrol mode can have an open end without needing to connect to any area or pathway.
  1. Adjust Patrol Line Settings:
Patrol Line Settings PagePatrol Line Settings Page
  • Patrol Level: There are four patrol levels:
    • Low: In-app notifications
    • Medium (Default): In-app notifications, voice prompt, app active push
    • High: In-app notifications, voice prompt, app active push, email alerts
    • Customize: Adjust detection targets, frequency, and notification methods based on your needs (as shown in the screenshot).
  • Turning Mode: Choose between zero-turn (default) or smart-turn options.
How to Create a Patrol Plan?
Creating a patrol plan is similar to creating a regular work plan:
  1. Tap the yellow "Start" icon on the main interface to enter the work plan page.
  2. Tap the "+" icon to add a patrol plan.
Patrol Line Work Plan PagePatrol Line Work Plan Page
  1. Select the patrol lines you want to add to the work plan, then tap the √ icon in the top-right corner. Your patrol work plan is now successfully created.
Patrol Line Work Plan Setting PagePatrol Line Work Plan Setting Page
How to Schedule a Patrol Work Plan:
Scheduling a patrol work plan is just like scheduling any other work plan:
  1. Go to the schedule page (accessible from either the "My Yard" page or the "Work Plan" page).
  2. Click the "+" icon to add a new schedule.
  3. Adjust the schedule settings:
Patrol Line Schedule SettingPatrol Line Schedule Setting
  • Start Time and End Time
  • Schedule Name
  • Select your patrol plan
  • Enable/Disable the plan
  • Frequency
  1. Click the √ icon to successfully create your patrol schedule.
    • [2024] Patrol Line FAQ
      Can the patrol line cross a no-go zone? No, a patrol line should not cross any no-go zone. How can I adjust the patrol speed? The patrol speed will follow the universal "moving speed" setting in the "Work Preferences" page. Adjust the moving speed ...
    • [2024] What is "Schedule"
      What is Schedule? The schedule feature within the app allows Yarbo to establish specific time periods for automated cleaning of work areas. By creating a schedule, Yarbo seamlessly operates without the need for manual intervention, ensuring that the ...
    • [2024] How to Utilize Schedule Feature
      1.What is schedule? The schedule feature within the app allows Yarbo to execute tasks automatically at specific times.By creating a schedule, Yarbo can operate seamlessly, executing tasks automatically without the need for manual intervention. ...
    • [2024] What is "Work Plan"
    • [2024] Create Work Plan through APP
