How to turn off the indicator light on your data center
[2024] How to turn off the indicator light on your data center
  1.  Click Data Center Setting
Data Center Setting
  1. Select the Data Center you want to adjust
Device Selection
  1. Click the light icon to turn on/off the DC light, and slide the bar to adjust the brightness of the DC light.
Data Center Light AdjutsmentData Center Light Adjutsment
    • [2024] What should I do if my Data Center flashes green light all the time?
    • [2024] Setting up a Data Center through your App
    • [2024] Yarbo User Manual
    • [2024] Replace Data Center quick guide
      Follow these simple steps to replace your Yarbo Data Center efficiently: In Yarbo Settings, click Replace Data Center.Notice:Your map data will be erased when you perform this action. Install Data Center according to the instructions in the User ...
