[2024] Battery Storage & Maintenance
Charge at least once every 3 months
Lithium‑ion cells self‑discharge over time. A 15‑minute top‑up charge every three months keeps the battery active.
Do not leave the battery inactive for more than 3 months
Extended inactivity accelerates capacity loss and degradation.
Even when idle, Yarbo consumes power
To protect the battery in cold weather, Yarbo automatically runs its heating system. Other systems — RTK positioning, HaLow connectivity, anti‑theft, and the operating system itself — also draw power when the machine is powered on.
Keep Yarbo docked when not in use
Yarbo’s Battery Management System includes over‑charge protection, so it’s safe to leave the unit plugged in and charging on its docking station between jobs.
Long‑term storage (over 3 months)
Power off Yarbo and remove the battery pack.
Store the battery in a cool, dry environment. The ambient temperature and humidity of the stored products shall meet the conditions specified in the form below, and shall be placed in a clean, day, ventilated room with moisture-proof, dust-proof, shock-proof and anticorrosive measures.
| Storage Temperature | ≤1 month | -20℃~60℃ |
| ≤3 month | -20℃~45℃ |
| ≤1 yaer | -20℃~20℃ |
| Storage Humidity | 0~70% RH
Use the wired charger to recharge for 15 minutes every three months to maintain health.
If you notice a significant decrease in its working hours:
You may contact us and we will consider offering you a replacement for the battery.
- The battery pack's lifespan is influenced by operation frequency and total working hours. If the operating time per full charge noticeably decreases, please consider replacing the battery pack.
[2024] Yarbo Battery Management Settings
These settings are designed for Yarbo's operation during a work plan, allowing for effective charging and battery management: Undock Battery Level: In an unfinished work plan, "Undock Battery Level" setting allows you to specify the battery ...
[2024] Yarbo Lawn Mower Maintenance Guide
[2024] Blower Routine Maintenance Guide
How to Perform Routine Maintenance for Your Yarbo Blower To keep your Yarbo Blower performing at its best and ensure its longevity, regular maintenance is essential. Below are the key steps you should follow to maintain your blower and keep it ...
[2024] Perform Routine Maintenance
[2024] Yarbo User Manual
