Yarbo Battery Management Settings – Undock, Recharge & Auger Off Levels
[2024] Yarbo Battery Management Settings
These settings are designed for Yarbo's operation during a work plan, allowing for effective charging and battery management:
battery management page
Undock Battery Level:
In an unfinished work plan, "Undock Battery Level" setting allows you to specify the battery percentage at which Yarbo will automatically leave the docking station to continue. You can customize the Undock Battery Level from 50% to 80%.
Recharge Battery Level:
“Recharge Battery Level ” indicates the minimum battery percentage required for operation. When the battery level falls below this threshold, the Yarbo will automatically return to the docking station for recharging. It can be customized to set the recharge battery level from 15% to 30% .
Turn off Auger Battery Level:
Yarbo will automatically turn off the auger when the battery level falls below this value to save power. It can be customized to set the Turn off Auger Battery Level from 10% to 15% .
    • [2024] Battery Storage & Maintenance
      Charge at least once every 3 months Lithium‑ion cells self‑discharge over time. A 15‑minute top‑up charge every three months keeps the battery active. Do not leave the battery inactive for more than 3 months Extended inactivity accelerates capacity ...
    • [2024] Setting your Work Preference for Lawn Mower
      This guide provides a detailed explanation of setting the working preferences, including Yarbo's moving speed and other settings during a work plan. Moving Speed: This feature sets the movement speed with three levels: Slowest, Slow, Medium, Fast, ...
    • [2024] Yarbo User Manual
    • [2024] Troubleshooting Guide: Yarbo Recharge Failure
      When you encounter a failure in recharging your Yarbo upon its return to the charging station, consider the following parallel factors that could contribute to the issue: Location and Positioning: Ensure that your Yarbo is within the map range. Your ...
    • [2024] How to recharge Yarbo
      Four ways to recharge Yarbo 1. Using the Physical Controller: Drive Yarbo back to the docking station with the physical controller. After approximately 3 minutes, Yarbo will announce "ready to charge" and "start charging," and will then begin ...
