Caution: In Cold Weather, DO NOT Touch Yarbo with Bare Hands
【Must Read】Safety Guidelines about Yarbo
Product Usage For the safety of yourself and your property during product usage, please adhere to the following guidelines: WARNING: Keep Away from Children: Never allow children to operate the product. Adult Supervision: Only let adults operate the ...
Warning: Do not Touch the Sensitive Sensors near the Side Camera
Cautionary Measures and Operational Precautions: Do not touch the heating film near the side cameras. This caution is especially important when the heating film reaches temperatures of up to 60 degrees Celsius or 140 degrees Fahrenheit when Yarbo's ...
Safety tips for charging and maintaining the mower's battery
The battery is a crucial component of the Yarbo, and its condition directly affects the operational efficiency and safety of the device. By following proper charging and maintenance practices, you can effectively extend the battery's lifespan, ensure ...
Caution: Clearing Ground Obstacles Before Using Yarbo
In preparation of operating Yarbo before each storm, please clear the pathways and areas of any debris. If it can damage a traditional two-stage snowblower, assume it can damage Yarbo. If foreign objects are in Yarbo’s way, it has the potential to ...
Keep Yarbo at its Best Performance
Before and after every operation, DO: Check the status of the discharge chute Notice: Operating with a clogged discharged chute can significantly shorten the motor's lifespan and lead to subpar snow removal performance. Caution: SHUT DOWN Yarbo ...
