How to add more areas to an existing map?
There are two ways to add more areas to an existing map. Please follow these steps for each method:
Add more areas option will be shown after your working area has been drawn, the throwing direction has been selected, route mode has been set.
Method 1: Adding More Areas from the Mapping Process
- During Mapping Area Process: While in the process of mapping the work area, after selecting the snow-throwing direction and proceeding to the route mode selection page, click on 'Next', and then click the 'Confirm' icon.
- Pop-up Window: A pop-up window will appear, asking if you want to make other options. Click on ' Add More Area' to access the tool for creating more areas.
- Accessing More Area Creation: In the pop-up window, click 'Add More Areas' to initiate the creation of new areas.
- Drawing More Area: When drawing more areas, ensure that you start the pathway from the edge of the previous working area. After completing the pathway, proceed to draw the new area.
- Completion: After drawing more areas, the subsequent steps remain the same as the initial area creation process.
Method 2: Add More Areas from the Modify Page
The additional areas need to be added starting from a specified area. Therefore, you need to first select a specific area. Subsequently, you can start drawing a pathway from this chosen area.
- Navigate to 'My Map' Page: Select the icon in the upper right corner to navigate to the 'My Map' Page.
- Access Area Modification: Click on 'Modify' to access the Area modification mode.
- Initiate Addition Process: Click "Add Area” to start the process of drawing a new area.
- Create a Pathway: Upon finishing mapping of the new work area, draw a pathway to connect it with the previous area.
There are two ways to add more areas to an existing map. Please follow these steps for each method: Add more areas option will be shown after your working area has been drawn, the throwing direction has been selected, route mode has been set. Method ...
Adding and setting a background for your map
Before proceeding, remember to search for a satellite map of your desired area using a platform like Google Earth. Take a screenshot of the area you wish to use as the background for your map. After preparing your satellite image screenshot, follow ...
Where to Find Mapping Feature?
Upon completing the tutorials, please click on the "Start Mapping" button to enter the Mapping section directly. If you accidentally exist the tutorials, locate the Plus Sign icon within the APP's interface. Click on the plus sign to return to the ...
How to add a background to your map?
