How to modify 'No-go Zone'?
1. Add a No-go zone:
Method 1: Add a no-go zone from the mapping process
After you select the route mode, click the 'Check Mark'.
Step 1: Select 'Create no-go zone' from the three other options
Step 2: Click 'Start' Draw your designated no-go zone
Step 3: Once you finish drawing the no-go zone, click the 'Next'
Method 2: Add a no-go zone from 'My Map' page
Step 1: Click "Modify"
Step 2: Select an appointed area
Step 3: Click '+' Sign to add a no-go zone on your selected area
Step 4: Click 'Start' Draw your designated no-go zone
Step 5: Once you finish drawing the no-go zone, click the 'Next'
Method 3: Add a no-go zone with a vehicle template
On 'My Map' page: (You will see the full map with a no-go zone you draw before)
Step 3: Click '+' Sign to draw another no-go zone or select a suitable template
Step 4: Select a template for a size of your vehicle
Step 5: Once the chosen template showing horizontally on the area, adjust it using the sliding bar located under the 'Rotate' section (move left: anti-clockwise; move right: clockwise)
Step 6: If you finish, click the 'Check Mark' at the top right corner
2. Redraw a No-go Zone
You can redraw the no-go zone on the specified working area.
    • How to modify 'No-go Zone'?
      1. Add a No-go zone: Method 1: Add a no-go zone from the mapping process After you select the route mode, click the 'Check Mark'. Step 1: Select 'Create no-go zone' from the three other options Step 2: Click 'Start' Draw your designated no-go zone ...
    • Instruction related to the mower's mapping
      This artical outlines the mapping process, which serves as the initial stage of autonomous operations. You don't need to create a new map if you have previously generated one for Snow Blower S1 using the app, unless modifications to the working area ...
    • How to Create the No-go zone?
      What is No-go zone? The ”No-go zone" refers to areas within the working zone where you don't want Yarbo to enter. You need to draw it as a closed-off area. You can designate areas such as your car in the driveway, flower beds in the yard, and other ...
    • How to add and modify the No-go Zones?
