How to Fix the Common Issues with Yarbo Tool?
Connectivity Issues with both Yarbo device and RTK Base :
- The Yarbo app can not connect to the rover via the hotspot connection. 【Rover -> Network-> Wi-Fi Connection】
- The hotspot of Yarbo's rover cannot be found on the setting page of the mobile device. 【Rover -> Network-> Wi-Fi Connection】
- The rover can not be connected to through the app, but it's essential to check the progress of the firmware update. 【Rover-> Firmware Update】
- The RTK Base can not be connected to Wi-Fi. 【Base ->WiFi Connection】
Troubleshooting Issues:
- The rover is stuck displaying colorful lights and will not reboot. 【Rover->Status->Deep Clean】【Rover->Status->Docker->Restart】
- Remote debugging is required, but there is no internet connection available【Rover-> Network-> Wifi Connection and 4G Connection】
Version Checking:
- It is necessary to check if the rover is on the latest firmware version. 【Rover->Firmware Update】
Additionally, the Yarbo Tool should be used for the following actions:
- Generating log files: When troubleshooting complex issues or when requested by the support team for further analysis.
- Restarting within Docker: If the Yarbo device encounters software-related issues that may be resolved by restarting within the Docker environment. This action is typically taken after other troubleshooting steps have been exhausted and when software instability is suspected as the cause of the problem.
- Go to "WiFi Connection". Click the drop-down and select the desired WiFi SSID. If the WiFi network you want to connect to is not shown. Please enter the WiFi network name (SSID) and enter the correct WiFi password. Then, click "Connect". Upon successful connection, the status in the lower right corner will indicate "WiFi Connection Successful." Once connected, select the "Get WiFi Status" button to confirm the connection status. If the Wi-Fi connection is successful. The Wi-Fi Current Status will be displayed as "Connected".
- To enable cellular data, navigate to "4G Connection" and slide the button to enable the 4G connection. Afterward, click the "Check" button to review the status and details of the cellular connection. The ICCID, RSSI, RSRQ, CSO, and signal values can be utilized to assess the connection status.
- Go to "Firmware Update" in the left menu. Look at the "Fetch" status and confirm that the completion percentage is 100%, indicating that the rover has successfully updated to the latest firmware version.
RTK Base
- Download and Install Yarbo Tool: Ensure you have the latest version of the Yarbo Tool installed on your laptop.
- Connect to Yarbo Base's Hotspot: Connect your laptop's WiFi to the Yarbo base's hotspot, named something like "Yarbo_base_XXXXXX.” The initial connection password is set to "87654321."
- Connect to Desired WiFi SSID: Select the desired WiFi SSID from the drop-down menu, enter the correct WiFi password, and then click "Connect." Afterward, click on "Get WiFi Status" to confirm a successful connection to the Yarbo base's hotspot via WiFi. The WiFi Current Status should now display as "Connected.
- Activate 4G Connection: Slide the button to enable the 4G connection, then click on "Check" to review the status.
##The Yarbo Tool (for windows and mac ) can in found in the attachment.
- Related Articles
- What are the steps to resolve typical problems encountered with the Yarbo Tool?- The Yarbo Tool should be used in the following situations Connectivity Issues with both Yarbo device and RTK Base : The Yarbo app can not connect to the rover via the hotspot connection. 【Rover -> Network-> Wi-Fi Connection】 The hotspot of Yarbo's ...
- 2023 Yarbo Snow Blower S1 User Manual- Please download the User Manual for 2023 Yarbo Snow Blower S1.
- How to troubleshoot connectivity issues between the app and the mower?- The APP Controls the Machine and often Disconnects Contact Support. Please reach out to Yarbo support for assistance. Provide SN code and stay connected, further diagnosis and confirmation of the problem will be conducted. Hotspot Issues ① Rover ...
- Instruction of 'Yarbo Sharing'- For collaborative work on your Yarbo, the following steps will guide you in granting other members access: Launch the Yarbo application on your device and navigate to your personal account page. Locate and select the option labeled "Yarbo Sharing". ...
- Instruction of 'Find My Yarbo'- Open your Yarbo application and locate the settings icon. Scroll through the options until you find "Find my Yarbo" and select it. Upon selection, satellite imagery will be displayed showing the precise locations of your Yarbo, the RTK Base Station, ...
