The APP Controls the Machine and often Disconnects
Contact Support. Please reach out to Yarbo support for assistance. Provide SN code and stay connected, further diagnosis and confirmation of the problem will be conducted.
Hotspot Issues
① Rover Hotspot is Not Detected on Mobile Device
Step 1: Restart Your Devices
Sometimes, a simple restart can resolve connectivity issues. Follow these steps:
- Turn off your mobile device and restart your Yarbo device.
- Wait for a few seconds and then turn them back on.
- Attempt to connect your mobile device to Yarbo's Rover Hotspot again.
Step 2: If the Rover Hotspot is still unable to find in your mobile device, please Use the Yarbo Tool
The Yarbo Tool is designed to assist in troubleshooting Wi-Fi connection issues. Follow these steps:
- Download and install the Yarbo Tool on your laptop.
- Open the Yarbo Tool and navigate to the Wi-Fi Channel function in the Rover section.
Please refer to the article "How to Fix the Common Issues with Yarbo Tool?" to follow the step by step guide to effectively address Wi-Fi connection issues with your Rover Hotspot.
Step 3: Contact Support
If the issue persists, please reach out to Yarbo support for assistance. Provide details about the problem and steps you've taken so far.
② The Phone is Connected to the Machine Hotspot, but cannot Operate the Machine
Step 1: Check APP Settings
- Make sure you have turned hotspot mode on.
- Check if APP display overflow status. If so, click the Clear Overflow button on the control page.
Step 2: If you have turned on hotspot mode but problem still exists, please Use the Yarbo Tool
- Connect your laptop WiFi to the Yarbo rover's hotspot. The default hotspot name should be something like "Yarbo_rover_XXXX". The password for the initial connection is set to "87654321"
- Launch the Yarbo Tool application on your laptop. Activate"Connected Yarbo" and ensure the serial number shown matches the serial number on the Yarbo rover unit you are connected to.
- Then click the "Refresh" button to review the resource usage statistics shown.
- Proceed to click "Deep Clean" and confirm by selecting "OK" when prompted. It will initiate a process to clear cached files and data from the device.
③ The Yarbo app can not connect to the rover via the hotspot connection
Step 1: Use the Yarbo Tool
Step 2: Contact Support
Internet Connection Issues
① The machine cannot connect to the router Wi-Fi
Step 1: Solve the Problem according to the Prompts
- WiFi connection failed, access point does not exist: refresh network list
- Router exception: Restart the router
- Incorrect password: Enter the correct password
- No available network: Check if Wi-Fi exists and the signal is good
Step 2: If Issue Persists, Use the Yarbo Tool
- Connect the computer to the machine hotspot. Click Network and find "WiFi Connection".
- Click connect to the target Wi-Fi, then click "Get Wi-Fi Status".
② The machine cannot connect to 4G
- Connect the computer to the machine hotspot. Click Network and find "4G Connection".
- Click the "connection" button.
