Instructions for setting snow-throwing directions
 1. While conducting the cleaning process, Yarbo is designed to expel snow, requiring the configuration of snow-throwing directions within its cleaning area.
1. While conducting the cleaning process, Yarbo is designed to expel snow, requiring the configuration of snow-throwing directions within its cleaning area. 2. Once the snow-throwing directions are set, Yarbo will automatically direct the snow in the specified direction.
3. Please ensure that the snow-throwing directions span a minimum of 3.3 feet.
4. For optimal operational efficiency, it is recommended to set the snow-throwing direction to be as long and wide as possible.
1. Guided animation in snow-throwing direction setup:
When entering the snow-throwing directions setup, you'll encounter a guided animation. You have the option to click "Don't show again" or directly click the "Confirm" button to proceed.
2. Setting snow-throwing directions:
To configure the snow-throwing directions, please click or slide along the boundary of the working area. Click the button at the bottom of the interface to switch between different setting modes.
3. Completion of snow-throwing direction setup:
After completing the snow-throwing directions set up, you have completed the fundamental mapping process. Click "Next" to proceed to the next step.
4. Error correction in snow-throwing directions:
 If any mistakes are made during the drawing, there's no need to worry. You can click "Redraw" to start over.
- Related Articles
- How to Set Snow-throwing Directions?- 1. While conducting the cleaning process, Yarbo is designed to expel snow, requiring the configuration of snow-throwing directions within its cleaning area. 2. Once the snow-throwing directions are set, Yarbo will automatically direct the snow in the ...
- 2023 Yarbo Snow Blower S1 User Manual- Please download the User Manual for 2023 Yarbo Snow Blower S1.
- How to Draw Snow-throwing Directions to Maximize Efficiency? - In the mapping process, snow-throwing directions should be set for your pathway and work areas (including sidewalks), which guides the chute to blow snow in the direction(s) of your choice. While the setting of these directions largely depends on the ...
