As winter approaches its end in many areas, it's time to prepare your snow blower for off-season storage. Spending time on prepping the machine for long-term storage will not only help maintain its performance but also improve its longevity.
1, Battery Care
There's no need to remove the battery for additional care; you can leave it on the main body. However, if you prefer to store the battery pack separately, ensure it's kept in a dry, cool place.
Furthermore, for users who haven't purchased the lawn mower module, allowing the battery pack to remain inactive for an extended period may reduce its performance and lead to fast degradation. We recommend charging the battery pack for at least 15 minutes once every 3 months.
2, Clean the Exterior
Start by thoroughly cleaning the exterior of Yarbo. Remove all dirt, ice, and snow residues to prevent rust and corrosion. Wipe it down with a wet cloth and mild soap, then thoroughly dry it afterwards.
3, Remove Any Rust with Sandpaper
The auger of your Yarbo might develop rust over time due to constant contact with snow during operation. Easily manage minor rust spots with sandpaper before storing it.
4, Lubricate the Track
Grease is essential for maintaining smooth rotation of the drive and road wheels, enhancing performance and prolonging service life. Apply grease to the track before storage. Refer to the
video tutorial for specific lubrication guidelines for your Yarbo. If you have questions about choosing grease lubrication, consult the comprehensive
guideline provided.
5, Use a Snowblower Cover
To protect your Yarbo during storage, it's recommended to cover it with our customized machine cover and module cover. Covers prevent dust and debris from accumulating on your S1 while not in use.
6, Store Yarbo appropriately
Store it to avoid direct sunlight and open flame.
Inspect Yarbo Regularly
Yarbo, a technologically advanced robot, is designed with numerous complex components that work in tandem to deliver high-performance operations. To ensure the sustained performance and longevity of Yarbo, we strongly recommend regular inspections, ...
Clean Yarbo Regularly
How to clean: DO NOT use solvents on plastic components, as commercial solvents can potentially harm the appearance and integrity of your Yarbo. USE a clean and gentle cloth or a brush to remove debris, mud and other particles. Special Notice: Rubber ...
Protect your Yarbo with Machine Covers
To protect your Yarbo, we offer a machine body cover and a module cover when your Yarbo won't be in use for extended periods. These covers are designed to safeguard your machine from dust and debris. How to Apply REMOVE the Battery Pack and make sure ...
Remove Accumulated Snow on Yarbo after Operation
During the snow season, Yarbo's frequent outdoor operations can lead to snow accumulation on various parts. This could potentially impact Yarbo's performance and efficiency. Therefore, it's essential to inspect and remove the accumulated snow ...
Keep Yarbo at its Best Performance
Before and after every operation, DO: Check the status of the discharge chute Notice: Operating with a clogged discharged chute can significantly shorten the motor's lifespan and lead to subpar snow removal performance. Caution: SHUT DOWN Yarbo ...
