How to Replace the Track Side Plate on Your Yarbo Snow Blower – Step-by-Step Guide
[2024] How to Replace Track Side Plate
Purpose of the Track Side Plate
The Track Side Plate is an important component designed to prevent snow from accumulating inside the tracks and reaching the motors, which could lead to operational malfunctions during snow removal. Your Yarbo Core comes with two plastic-painted Track Side Plates pre-installed. To enhance performance during snow-blowing, we recommend replacing the plastic side plates with the more robust metal Track Side Plates when you install the Snow Blower module. track side plate
When to Replace the Track Side Plates
When you are ready to attach the Snow Blower Module to Yarbo, it’s the ideal time to replace
the Track Side Plates with the metal version. The metal Track Side Plates provide better durability
and optimal snow-blowing performance, ensuring that Yarbo continues to operate effectively
in snowy conditions.
Step-by-Step Instructions for Replacement
Step 1: Gather the Tools
  • You will need a Allen Key#2 that fits the screws used on the Track Side Plates.
    allen key #2
  • Ensure you have the replacement metal Track Side Plates ready.
    track side plate
Step 2: Remove the Existing Plastic Track Side Plates
  • Locate the Screws: The Track Side Plate is held in place by four screws.
  • Unscrew the Screws: Using your screwdriver, carefully unscrew the four screws securing the
    plastic Track Side Plate. Refer to the image below for visual guidance on unscrewing the Track
    Side Plates.
    track side plate unscrew
Step 3: Replace with Metal Track Side Plates
  • Position the Metal Side Plate: Place the new metal Track Side Plate in the same position where
    the plastic one was removed.
  • Secure with Screws: Use the same screws to securely attach the metal Track Side Plate. Make sure the screws are tightened properly to avoid any movement during Yarbo’s operation. track side plate screw
Step 4: Double-Check Installation
  • After securing the Track Side Plate, double-check that the screws are tight and the side plate
    is positioned correctly.
  • This is important to prevent any potential loosening during Yarbo's work, which might affect
    the machine's efficiency.
Benefits of Metal Track Side Plates
  • Enhanced Protection: The metal Track Side Plates provide superior protection from snow
    accumulation compared to the plastic version.
  • Better Durability: They are more resistant to impact and wear, making them suitable for
    heavy-duty snow-clearing operations.
  • Improved Performance: By keeping the tracks clear of snow, the metal side plates ensure
    consistent performance without interruptions due to motor clogging.
    • [2024] How to Replace Your Track to Fit the Snow
      Welcome to the Yarbo Track Replacement Guide. This guide provides a step-by-step process for safely removing and replacing the tracks on your Yarbo Core. By following these instructions, you can ensure a smooth and safe replacement process without ...
    • [2024] Refill Grease oil to the Track Regularly
      1.Grease Lubrication Purchase Guideline Grease Lubrication Types: All of these three types are applicable High Vacuum Grease Recommended for applications with high vacuum conditions. Ideal for sealing and lubricating vacuum systems. Vacuum Grease ...
    • [2024] Replace Data Center quick guide
      Follow these simple steps to replace your Yarbo Data Center efficiently: In Yarbo Settings, click Replace Data Center.Notice:Your map data will be erased when you perform this action. Install Data Center according to the instructions in the User ...
    • [2024] Yarbo Lawn Mower Maintenance Guide
    • [2024] How Does Yarbo Achieve Self-Rescue During Snow Blowing Work Plan
      When using the Yarbo snow blower module in thick snow conditions, the device is equipped with an automatic track slippage recovery mode to help it overcome obstacles and continue operating effectively. How the Track Slippage Recovery Mode Works: ...
