[2024] Setting up Docking Station through your App
This guide provides step-by-step instructions for setting up your Docking station, along with key considerations to ensure Yarbo maintains a wonderful charging base for wireless charging. You’ll also learn how to seamlessly reinstall your Docking station to a new location if needed. Follow these guidelines to ensure Yarbo’s optimal performance, wherever you choose to deploy it.
Installing the Docking Station
The key consideration when installing the Docking Station is to ensure it has at least 7 feet of clearance in all directions. This is essential for optimal wireless charging experience.
Docking Station Signal lights
To ensure the best wireless charging experience, make sure that the light on the docking station should be solid blue to be ready to charge.you can also refer to the sheet below to confirm the status of Docking Station.
Reinstall Docking Station
If you need to move your Docking Station to a new location, follow these steps to ensure a smooth transition.
When you reinstall the Docking Station, any connected pathway will be deleted.
- Initiate Relocation
Go to the Settings page in the app, select Reinstall Docking Station, and confirm Docking Station Relocation to begin the process.
Main page -> Yarbo Settings -> Reinstall Docking Station
- Place Your Docking Station
Place the Docking Station on the ground and keep an eye on the screen in the app on your phone. When you find the spot where the Network and GPS shows “Strong” and there are at least 7 feet of the clearence in all directions,which is a suitable location to place the Docking Station.
- Make sure you have already installed the Docking Station and docking station's light is solid blue. Place the Yarbo on the docking station and adjust the position until the Save Position button is clickable, or use verification and then adjust the position until the Save Position button is clickable.
- Click Save Position and wait a few seconds for the docking station to be saved successfully. After it is saved successfully, you can see congratulations.
[2024] Maintaining Data Center and Docking Station Position for Accuracy
For Yarbo to function at its best, it's crucial to ensure that both the Data Center and the Docking Station are placed and maintained in the optimal positions. Correct placement of these components helps Yarbo accurately navigate, recharge ...
[2024] Setting up a Data Center through your App
[2024] What is "Docking Station"
The Docking Station is a smart charging platform specifically designed for Yarbo. It provides seamless wireless charging and auto-return functionality, ensuring the device stays powered and operational without manual intervention. Key Features: ...
[2024] Instruction of Setting Page of Yarbo APP
The Yarbo Settings Page provides you with complete control over all the essential aspects of your Yarbo device, allowing you to make adjustments, update settings, and access valuable information. This guide will take you through each feature of the ...
[2024] Yarbo Lawn Mower Quick Start Guide
Please download the attached file for the Quick Start Guide of the 2024 Lawn Mower.
