[2024] How to Activate/Deactivate the Auger When Starting a Workplan
The Auger is a key component in your Yarbo's snow removal system, and being able to easily activate or deactivate it ensures that your Yarbo can adapt to different working conditions. This guide will walk you through how to adjust the auger settings in the Yarbo app so that you can control whether the auger is active during your work plan.
Why Control the Auger?
The auger is responsible for removing snow effectively, but there may be times when you don't need it to be active—for example, when there's no snow present. Deactivating the auger when it's not needed can help conserve power and prevent unnecessary wear.
Important Note: It is recommended to turn off the auger only when there is no snow present, as keeping it off during snowy conditions may reduce the efficiency of your Yarbo's performance.
Steps to Activate/Deactivate the Auger Using the Yarbo App
Follow these simple steps to control the auger during a work plan:
Step 1: Open the Yarbo App
- Launch the Yarbo app on your mobile device.
Step 2: Select Your Yarbo Device
- From the main dashboard, select your Yarbo device. This will bring up the controls and settings for your Yarbo.
- Tap on the settings icon (usually represented by a gear icon) to access the settings menu for your Yarbo.
Step 4: Navigate to "Work Preference"
- Scroll through the settings menu and tap on "Work Preference". This section allows you to customize how Yarbo operates during its work plan.
Step 5: Adjust the Auger Setting
- In the Work Preference section, look for the option labeled "Auger in Work Plan".
- You will see a toggle switch next to "Auger in Work Plan":
- To Activate the Auger: Make sure the toggle switch is turned on. This means the auger will operate during the work plan.
- To Deactivate the Auger: Simply toggle off the switch. Yarbo will not activate the auger during the work plan when this is off.
Step 6: Save Your Preferences
- Once you have made your desired changes, tap the checkmark icon or any "Save" button to confirm your settings.
Testing Yarbo with the Updated Settings
After configuring the auger settings in the Yarbo app, it's a good idea to test Yarbo to make sure it's running smoothly and safely:
- Start a Work Plan: Use the Yarbo app to start a new work plan.
- Observe Yarbo's Operation: Depending on whether you've activated or deactivated the auger, monitor how Yarbo handles the terrain. This can help you confirm that the auger settings are functioning correctly based on the conditions.
[2024] Create Work Plan through APP
[2024] What is "Work Plan"
[2024] How to set the number of Perimeter Mowing Laps in the lawn mowing work plan
To enhance the efficiency and completeness of lawn mowing, especially along the boundaries, the Yarbo mower module now includes a feature to set the number of Perimeter Mowing Laps. This feature helps prevent missed areas and ensures a thorough ...
[2024] How to Operate the Auger Safely?
The Yarbo Snow Blower is designed to efficiently clear snow from surfaces, but handling the auger safely is essential to prevent injury or equipment damage. This guide provides important safety considerations to ensure the safe operation of the Yarbo ...
[2024] Why is your work plan not working?
Docking Station and Pathway Setup When creating your work plan, it is essential to first ensure that the docking station is properly set up. Once the docking station is in place, you must draw a pathway that connects it to your designated work area. ...
