How to Activate the Auger/Impeller When Drawing a Map?
If you need to draw working areas in the presence of snow, you could activate the auger to assist in clearing the snow in your way:
- Open the control panel by clicking the button at the bottom right corner of the working area drawing page.
- Choose the auger(Impeller) speed from the options available at the bottom left corner of the control panel.
Instruction related to the mower's mapping
This artical outlines the mapping process, which serves as the initial stage of autonomous operations. You don't need to create a new map if you have previously generated one for Snow Blower S1 using the app, unless modifications to the working area ...
Where to Find Mapping Feature?
Upon completing the tutorials, please click on the "Start Mapping" button to enter the Mapping section directly. If you accidentally exist the tutorials, locate the Plus Sign icon within the APP's interface. Click on the plus sign to return to the ...
How to add more areas to an existing map?
There are two ways to add more areas to an existing map. Please follow these steps for each method: Add more areas option will be shown after your working area has been drawn, the throwing direction has been selected, route mode has been set. Method ...
