[2023] A Comprehensive Overview about the RTK Base
What is the RTK Base? RTK, or Real-Time Kinematicis a method that boosts the precision of GNSS (Global Navigation Satellite System) signals like GPS, Glonass, Galileo, and BeiDou. The main purpose of the base station is to remain fixed in one ...
How to Install the HaLow Module?
Preparation Before you begin, ensure you have all the necessary components and tools: Ethernet Cable RTK Base with HaLow Module Black HaLow Antenna for Rover Black HaLow Antenna for Base Battery Cover with HaLow Module (USB and Type C cable) Yarbo ...
Securing the RTK Antenna
Make sure the RTK Antenna structure is securely fastened. Any movement in the structure of the antenna will directly affect the accuracy of Yarbo’s positioning.
【Troubleshooting】What Should I Do if my RTK Base Flashes Green Light All the Time?
How to install a new rear cover?
Things you need to prepare ahead Lawn Mower Module Box Content: Steps Loosen all the anti-slip studs on the track with Socket #1 or any electronic tools(not provided). Please ignore this step if there are no anti-slip studs on the track. Install the ...
